Thread: XDATA attached to SSI Pipe objects
    Active Member Tommybluegrass's Avatar
    Mississippi Gulf Coast, U.S.A.
    74
    Default XDATA attached to SSI Pipe objects
    What happen if I add xdata to SSi piping or HAVC objects? Will the SQL database keep the xdata? Is there a problem adding XDATA ? If so why?
    Default Re: XDATA attached to SSI Pipe objects
    You can add XData to the ShipConstructor entities but the XData will not be stored in the database.
    There are no issues with adding XData to ShipConstructor parts but anytime ShipConstructor recreates the part (recreating model/system drawings) or creates production drawings (spool, assembly, arrangement, etc.) the XData will be lost. If you are just updating your model drawings and production drawings you should be Ok.
    74
    Ok thanks Dennis- that is a bit clearer. What is the SCXDATA command for? Searching the knowledge base I do not find much information on this tool. No examples for its use - nothing.
    SCXDATA displays the XData with a specific XDATA application name and only for specific entities. To be honest the best way to manage XDATA is using the Express Tools which can be installed with AutoCAD or any of it's verticals.
    74
    OK that makes sense - thanks
  1. Replies: 6
    Last Post: 2015-08-31, 04:05 PM
  2. Pipe network merging objects
    Last Post: 2015-01-26, 04:49 PM
  3. ESRI shape objects in attached dwg
    By jmauro930585 in forum AutoCAD Civil 3D - General
    Last Post: 2012-03-01, 12:32 AM
  4. Family rotates when horizontal pipe is attached
    By bschottke in forum Revit MEP - General
    Last Post: 2009-10-13, 04:39 PM
