Thread: redefine F10 key mapping
    I could stop if I wanted to gordolake's Avatar
    2004-05
    Australia
    205
    Question redefine F10 key mapping
    Hi all,
    I was wanting to customize my F10 key to zoom window, but it is not an option in the accelerator key dialogue box.
    Is there a work around for this (2005)
    Thanks
    Steve.
    13,656
    Default Re: redefine F10 key mapping
    Hi
    Check out the following Technical Documents on the Autodesk web site under the Knowledge Base section -
    ID: TS20858 - Assign an AutoLISPĀ® routine to a shortcut key
    ID: TS22496 - Create accelerator keys (keyboard shortcuts) for commands
    The following threads should help....
    Disabling Help
    Hot key/shortcut key for Polar, Osnap & Otrack
    Customising the Function Keys
    Have a good one, Mike
    2004-05
    Australia
    205
    Thanks Mike,
    I do now remember the menu file accelerator keys section. will give it a go.
    Q. for Desk, why leave F10 and others? out of the customization dialog edit routine?
    Steve
    Earth
    9,803
    Quote Originally Posted by gordons.68934
    Thanks Mike,
    Steve
    F10 is a special windows key (to activate the menu bar in the active program)
    See: http://labmice.techtarget.com/articles/keyboard.htm
    13,656
    Quote Originally Posted by rkmcswain
    Hi
    In addition take a look at the following within the AutoCAD Online Help File [F1] -
    Contents tab -> Command Reference -> Commands -> C Commands -> Customize -> Customize Dialog Box -> Keyboard Tab (Customize Dialog Box)
  1. Redefine F1
    By RobertB in forum AutoCAD CUI Menus
    Last Post: 2014-06-11, 04:13 PM
  2. Redefine Blocks
    By adampatten in forum AutoCAD General
    Last Post: 2008-08-14, 02:27 PM
  3. Redefine Groups
    By nnguyen in forum Revit Architecture - General
    Last Post: 2006-10-04, 09:55 PM
  4. Attribute redefine.
    By revacservice in forum AutoCAD General
    Last Post: 2006-09-08, 11:10 PM
  5. Redefine Qleader
    By jpaulsen in forum AutoLISP
    Last Post: 2004-11-18, 12:49 PM
