Results 1 to 6 of 6
Thread: Multiple Selection Sets To One Line Lisp
    2009-10
    262
    Default Multiple Selection Sets To One Line Lisp
    Does anyone know of a lisp in which I can make multiple selection sets line up with a line?
    For example you could select a number of groups and assign corresponding points with the groups the select a vertical line along the y axis have all selection sets and there selected points snap to that line.
    Example start and end result included
    2009-11
    5,719
    Default Re: Multiple Selection Sets To One Line Lisp
    Something like Lee's TXALIGN?
    Computer Specs:
    2009-10
    262
    Close, except the objects wont be grouped together, so multiple selection sets are required in order to in order to temporarily group the objects of each individual selection set with one another
    Then assigning each group of selection sets there own unique point...
    In order to line up all groups in the selection sets with the line like this
    Certifiable AUGI Addict
    2001-03
    Tallahassee, FL USA
    3,667
    Quote Originally Posted by mbrandt5 View Post
    You could use Lee Mac's http://lee-mac.com/ssboundingbox.html to get a list of the lower-left and upper-right WCS coordinates of a rectangular frame bounding all objects in supplied selection set (s). Subtract the x value of the mid point of the lower-left and upper-right WCS coordinates from the x value you want to move the selection set, repeat for each selection set.
    A Lee Mac example using this for move: http://www.cadtutor.net/forum/showth...l=1#post632768
    2009-10
    262
    Not sure I understand...So your aware the purpose of me wanting to do this is to eliminate a move commands...seeing I would
    Select objects
    Select point
    Select End Point
    Entering move each time I do the command and selecting the end point each time I do the additional move just seems like pointless strokes
    If your link does do this would you mind explaining how to clear up my confusion?
    2001-03
    Tallahassee, FL USA
    3,667
    Select objects
    Select point
    Select End Point
    Not exactly what you were looking for, just thought it was close enough to get you started.
  1. Pass vba selection set to lisp or command line?
    By KevinBarnett in forum VBA/COM Interop
    Last Post: 2019-02-15, 04:23 PM
  2. 2014: Selection Sets mapped to multiple tasks in timeliner
    By markfo in forum NavisWorks - General
    Last Post: 2015-08-31, 08:42 PM
  3. Selection sets in multiple drawings..re-visit
    By okonforti.91529 in forum AutoLISP
    Last Post: 2010-10-29, 10:42 PM
  4. selection sets in multiple drawings
    By mdsalman2003 in forum AutoLISP
    Last Post: 2010-06-21, 05:01 PM
  5. Keep multiple selection sets in memory
    Last Post: 2005-10-11, 03:50 PM
