mbrandt5
Try this modified from Convert Fields to Text in Paper Space by: Ian_Bryant:
;| Convert All Fields to Text in drawing modified from Convert Fields to Text in Paper Space by: Ian_Bryant
http://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/convert-field-to-text/td-p/1722015 |;
(defun C:R-FIELDS-ALL ( / del-field ss1 index item)
(vl-load-com)
(defun del-field (ent / edic elist etype obj val)
(if
(and
(setq edic (cdr (assoc 360 (setq elist (entget ent)))))
(dictsearch edic "ACAD_FIELD")
(progn
(setq obj (vlax-ename->vla-object ent)
etype (cdr (assoc 0 elist))
(cond
((= etype "DIMENSION")
(setq val (vla-get-textoverride obj))
(dictremove edic "ACAD_FIELD")
(vla-put-textoverride obj val)
((= etype "MTEXT")
(setq val (vla-get-textstring obj))
(vla-put-textstring obj val)
(T (dictremove edic "ACAD_FIELD"))
(if
(setq ss1
(ssget "X" '((0 . "TEXT,MTEXT,MULTILEADER,DIMENSION")))
(progn
(setq index 0)
(repeat (sslength ss1)
(setq item (ssname ss1 index))
(if (del-field item) (entupd item))
(setq index (+ 1 index))
(if
(setq ss1
(ssget "X" '((0 . "INSERT")))
(progn
(setq index 0)
(while (= (cdr (assoc 0 (entget (setq item (entnext item))))) "ATTRIB")
(princ)
another Convert Fields from selected objects to Text modified from Convert Fields to Text in Paper Space by: Ian_Bryant:
;| Convert Fields from selected objects to Text
(defun C:R-FIELDS ( / del-field ss1 index item)
(vl-load-com)
(if
(and
(progn
(cond
((= etype "MTEXT")
(if
(setq ss1
(ssget '((0 . "TEXT,MTEXT,MULTILEADER,DIMENSION,INSERT")))
(progn
(setq index 0)
(if(=(cdr(assoc 0(entget item))) "INSERT")
(princ)
