Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: General Notes
    100 Club Chris DiSunno's Avatar
    2004-10
    East Hampton, NY
    171
    Red face General Notes
    For small projects we use a general notes page filled with text from the 16 divisions. Now we have 8 columns of text on a 23x36 sheet. We edit each column to cut and paste from the top to bottom of each column as the notes change and apply or don't to a project. There has got to be a better way. A text family? A multi column single text piece w/ top & bottom limit?
    Any thoughts?
    2002-02
    St. Louis, MO
    4,695
    Default Re: General Notes
    Two options.
    1. Make the text and the group it. Place that group on each sheet. Updating one group will update all sheets.
    2. Create a legend view. Place that on each sheet. Updating the legend view will update each sheet.
    Both are quite simple.
    2004-10
    East Hampton, NY
    171
    I wasn't clear. All the text is on one sheet. I'm changing the content of the text on that sheet which changes the length of the column. For example, add three paragraphs on concrete floor finishing and the column runs off the page. So I cut the runoff from the bottom of the column and add it to the top of the next column and so on until I reach the end. This is a good example as concrete is "Division 3" modifying columns all the way to Division 16 - Electrical.
    NavisWorks Moderator david.kingham's Avatar
    2004-07
    Fort Collins, CO
    1,329
    Would be awfully nice if we could break up text like you can with schedules
    2004-10
    East Hampton, NY
    171
    Exactly David!!!
    That's the way to go.
    I'm gonna mess with schedules to try a work around
    All AUGI, all the time J. Grouchy's Avatar
    2003-12
    Quhl Whirled
    896
    It'd be nice to be able to edit large amounts of text within a schedule...which leads me back to this wish I made a while back but really never got answered.
    Revit Founder LRaiz's Avatar
    2003-07
    Newton, MA
    714
    I suspect Note Blocks will do what you are looking for and will automate your work considerably. Look them up in Help. Noteblocks will provide schedule-like functionality and as an extra benefit they give an ability to create notes with leaders pointing to specific places in your views. If not clear post an image of your sheet with notes to clarify the need. May be someone should take the time to write a tutorial on note-blocks.
    2002-02
    St. Louis, MO
    4,695
    Ah. Revit need to just buy CorelDraw and incorporate its text tools.
    2004-10
    East Hampton, NY
    171
    Smile Re: General Notes
    IT WORKS!
    Sorry been in a meeting, I'm preparing a sample
    2004-10
    East Hampton, NY
    171
    O.K. Here it is.
    Since you need objects to create a schedule, I created a furniture schedule. I chose that because I'm not using it in this project and I have furniture in the presentation drawings.
    I made a filter to include only those listed for the divisions I created and used only the comments and description columns, then hid descriptions.
    Just substitute your text for the comments for each section.
    I havn't figured out how to get rid of the totle from each column, but I havn't looked yet.
    Chris
  1. General Notes/ Plan Notes/ Sheet Notes
    By ubviswa in forum Revit Structure - General
    Last Post: 2012-12-04, 05:32 PM
  2. General Notes
    By lbeyer593018 in forum Revit Structure - General
    Last Post: 2012-09-10, 07:55 PM
  3. General Notes
    By bwooten in forum Revit Structure - Wish List
    Last Post: 2009-06-04, 11:08 PM
  4. General Notes / Key Notes
    By lonewolfjustin in forum Revit MEP - General
    Last Post: 2008-11-25, 02:31 AM
  5. General Notes
    By rflores.73491 in forum AutoCAD General
    Last Post: 2004-09-10, 07:25 PM
