Thread: Need LISP for Divide SPline (or Polyline) Into Different Lengths Based On Input
    2013-03
    16
    Default Need LISP for Divide SPline (or Polyline) Into Different Lengths Based On Input
    The task should be similar to the _measure command but, I would like to divide the spline into lengths that I give in input. (Decided by user)
    e.g. Length of spline: 10.000 meters
    Place a block at length:
    - 1238 m
    - 2005 m
    - 2018 m
    - 2458 m
    - 4098 m
    and so on..
    How I can do that? It would be perfect if it would be possible to give an excel file with the length values.
    2003-07
    555
    Default Re: Need LISP for Divide SPline (or Polyline) Into Different Lengths Based On Input
    Here is a start draws a point at the distance needs a lot more like don't exceed length.
    (setq entSelection (car (entsel "\nSelect OBJECT To Divide: ")))
    (setq objSelection (vlax-ename->vla-object entSelection))
    (WHILE (/= DIST 0.0)
    (setq DIST (getreal "\Enter offset distance 0 to exit"))
    (command "point" (vlax-curve-getpointatdist objSelection DIST))
    2010-10
    535
    Quote Originally Posted by radosak368138 View Post
    ...The task should be similar to the _measure command but, I would like to divide the spline into lengths that I give in input. (Decided by user)
    Place a block at length:...and so on..
    (defun c:demo ( / doc spc obj dst d distancevalue)
      (setq	doc (vla-get-activedocument (vlax-get-acad-object))
    	spc (vlax-get-property
    	      doc
    	      (if (= 1 (getvar 'CVPORT))
    		'Paperspace
    		'Modelspace
      (if (and (setq distancevalue nil
    		 obj (car (entsel)))
    	   (wcmatch (cdr (assoc 0 (entget obj))) "*LINE")
    	   (setq dst
    		  (vlax-curve-getdistatparam obj (vlax-curve-getendparam obj))
    	    (while
    	      (progn
    		(setq d (getdist "\nEnter distance: "))
    		(cond
    		  ((null d) nil )
    		  ((> d dst) d (princ "\nExceeds Entity Length"))
    		  (T
    		   (Vlax-invoke spc
    		     'InsertBlock (vlax-curve-getpointatdist obj d)
    		     "BlockName"  1 1  1 0
    		   (setq distancevalue (cons d distancevalue))
    		   (princ (strcat "\nBlock inserted at distance " (rtos d 2 2))
        (princ "\nInvalid Object")
      (foreach p (reverse distancevalue)
        (print p))
      (princ)
    (vl-load-com)
    EDIT: Oops, There's another thread just like this. my bad
  1. Need Lisp for divide polyline in custom length
    By radosak368138 in forum AutoLISP
    Last Post: 2015-07-29, 12:31 AM
  2. Replies: 1
    Last Post: 2015-03-19, 02:55 PM
  3. List total Polyline lengths according to Layer
    By irchrismm in forum AutoLISP
    Last Post: 2011-07-11, 07:10 AM
  4. Spline divide with VB6
    By srobillard in forum VBA/COM Interop
    Last Post: 2007-09-12, 10:53 AM
  5. polyline lengths
    By eebryant in forum AutoCAD Map 3D - General
    Last Post: 2006-11-04, 01:18 PM
