Thread: Quick rotate and / or move-rotate
    2015-05
    Default Quick rotate and / or move-rotate
    Hi,
    I am after a couple command if anyone knows of one please, to:
    1) Quick rotate text - in other words, simply click the text and click somewhere in space to rotate it. It will always automatically use it's insert point as the base point. and:
    2) Quick move and rotate - similarly, select text, place somwhere, then click in space for it's orientation. Always using insert point as base point. IE without having to move/enter/select/enter/base point/destination/rotate/enter/base/rotation.
    If anyone can help, that would certainly be great!
    Rroger_D
    2015-08
    North Dakota
    4
    Default Re: Quick rotate and / or move-rotate
    Hi Rroger_D
    One thing I recommend is making your text annotative, that way you can set the text to auto adjust its rotation based on the orientation of your layout. I use this feature a lot when I have text displaying through multiple viewports and want them to appear readable on every viewport regardless of how the model space is rotated through the viewport. You can simply check a box in the text style window and all your text will auto rotate to match your layout/viewport.
    Another option that is built into AutoCAD is to type the rotation angle into the properties window and the text will rotate about its basepoint.
    There is also a tool in the Express Tools Ribbon called Modify Text that will allow you to rotate the text to match the orientation of a line you draw:
    These are the main options that come with AutoCAD, if you are still seeking a tool to do this even faster you can install plugins or lisp commands that will streamline the task even more.
    Hope this helps with your question.
    5,719
    As requested, here are some quickly written LISP routines....
    Quote Originally Posted by Rroger_D View Post
    Quick Rotate Text:
    (vl-load-com)
    (defun c:QuickRotateText (/ *error* ss v pt ang acDoc)
      (defun *error* (msg)
        (cond ((not msg))                                                   ; Normal exit
              ((member msg '("Function cancelled" "quit / exit abort")))    ; <esc> or (quit)
              ((princ (strcat "\n** Error: " msg " ** ")))                  ; Fatal error, display it
      (while
        (and
          (setq ss (ssget ":S:E:L" '((0 . "MTEXT,TEXT"))))
          (setq v (vlax-ename->vla-object (ssname ss 0)))
          (setq ang
                 (acet-ss-drag-rotate
                   ss
                   (trans
                     (setq pt
                            (vlax-get
                              v
                              (cond
                                ((= "AcDbMText" (vla-get-objectname v))
                                 'insertionpoint
                                (T 'textalignmentpoint)
                   T
          (or acDoc
         (vla-startundomark acDoc)
         (vla-rotate v (vlax-3d-point pt) ang)
         (vla-endundomark acDoc)
      (*error* nil)
    Quick Move And Rotate Text:
    (vl-load-com)
    (defun c:QuickMoveRotateText (/ *error*  ss v pt1 pt2 acDoc ang)
      (while
        (and
          (setq pt2
                 (acet-ss-drag-move
                   ss
                   (trans
                     (setq pt1
                            (vlax-get
                              v
                              (cond
                                 'insertionpoint
                   "\nSpecify second point: "
                   T
          (or acDoc
        (vlax-invoke v 'move pt1 pt2)
        (if (setq ang (acet-ss-drag-rotate ss (trans pt2 0 1) T))
          (vla-rotate v (vlax-3d-point pt2) ang)
      (*error* nil)
    For completeness, here's another....
    Quick Copy And Rotate Text:
    (vl-load-com)
    (defun c:QuickCopyRotateText (/  *error* ss v pt1 pt2 acDoc oText ang)
        (if oText (vla-delete oText))
      (while
        (and
          (setq pt2
                 (acet-ss-drag-move
                   ss
                   (trans
                     (setq pt1
                            (vlax-get
                              v
                              (cond
                                 'insertionpoint
                   T
          (or acDoc
        (vlax-invoke (setq oText (vla-copy v)) 'move pt1 pt2)
        (setq ss nil ss (ssadd (vlax-vla-object->ename oText)))
          (progn
            (vla-rotate oText (vlax-3d-point pt2) ang)
          (vla-delete oText)
        (setq oText nil)
      (*error* nil)
    Cheers
  1. Cannot see Objects as I move or rotate them
    By chrisr in forum AutoCAD General
    Last Post: 2010-07-19, 12:49 PM
  2. Copy/Move/Rotate
    By joshua.harter in forum ACA General
    Last Post: 2010-01-28, 08:58 PM
  3. Rotate then move in a dynamic block
    By Jonathan Pitt in forum AutoCAD General
    Last Post: 2009-06-30, 11:28 AM
  4. rotate then move
    By chad.beussink in forum AutoLISP
    Last Post: 2008-08-22, 01:23 PM
  5. Can not see Objects as I Move them or Rotate them
    By hugvi76 in forum AutoCAD General
    Last Post: 2005-01-19, 10:04 PM
