Thread: Quick rotate and / or move-rotate
    2015-05
    3
    Default Quick rotate and / or move-rotate
    Hi,
    I am after a couple command if anyone knows of one please, to:
    1) Quick rotate text - in other words, simply click the text and click somewhere in space to rotate it. It will always automatically use it's insert point as the base point. and:
    2) Quick move and rotate - similarly, select text, place somwhere, then click in space for it's orientation. Always using insert point as base point. IE without having to move/enter/select/enter/base point/destination/rotate/enter/base/rotation.
    If anyone can help, that would certainly be great!
    Thanks
    Rroger_D
    2015-08
    North Dakota
    4
    Default Re: Quick rotate and / or move-rotate
    Hi Rroger_D
    One thing I recommend is making your text annotative, that way you can set the text to auto adjust its rotation based on the orientation of your layout. I use this feature a lot when I have text displaying through multiple viewports and want them to appear readable on every viewport regardless of how the model space is rotated through the viewport. You can simply check a box in the text style window and all your text will auto rotate to match your layout/viewport.
    Another option that is built into AutoCAD is to type the rotation angle into the properties window and the text will rotate about its basepoint.
    There is also a tool in the Express Tools Ribbon called Modify Text that will allow you to rotate the text to match the orientation of a line you draw:
    These are the main options that come with AutoCAD, if you are still seeking a tool to do this even faster you can install plugins or lisp commands that will streamline the task even more.
    Hope this helps with your question.
    2009-11
    5,534
    As requested, here are some quickly written LISP routines....
    Quote Originally Posted by Rroger_D View Post
    Quick Rotate Text:
    (vl-load-com)
    (defun c:QuickRotateText (/ *error* ss v pt ang acDoc)
      (defun *error* (msg)
        (cond ((not msg))                                                   ; Normal exit
              ((member msg '("Function cancelled" "quit / exit abort")))    ; <esc> or (quit)
              ((princ (strcat "\n** Error: " msg " ** ")))                  ; Fatal error, display it
        (princ)
      (while
        (and
          (setq ss (ssget ":S:E:L" '((0 . "MTEXT,TEXT"))))
          (setq v (vlax-ename->vla-object (ssname ss 0)))
          (setq ang
                 (acet-ss-drag-rotate
                   ss
                   (trans
                     (setq pt
                            (vlax-get
                              v
                              (cond
                                ((= "AcDbMText" (vla-get-objectname v))
                                 'insertionpoint
                                (T 'textalignmentpoint)
                   T
          (or acDoc
              (setq acDoc (vla-get-activedocument (vlax-get-acad-object)))
         (vla-startundomark acDoc)
         (vla-rotate v (vlax-3d-point pt) ang)
         (vla-endundomark acDoc)
      (*error* nil)
    Quick Move And Rotate Text:
    (vl-load-com)
    (defun c:QuickMoveRotateText (/ *error*  ss v pt1 pt2 acDoc ang)
        (princ)
      (while
        (and
          (setq pt2
                 (acet-ss-drag-move
                   ss
                   (trans
                     (setq pt1
                            (vlax-get
                              v
                              (cond
                                 'insertionpoint
                   "\nSpecify second point: "
                   T
          (or acDoc
        (vlax-invoke v 'move pt1 pt2)
        (if (setq ang (acet-ss-drag-rotate ss (trans pt2 0 1) T))
          (vla-rotate v (vlax-3d-point pt2) ang)
      (*error* nil)
    For completeness, here's another....
    Quick Copy And Rotate Text:
    (vl-load-com)
    (defun c:QuickCopyRotateText (/  *error* ss v pt1 pt2 acDoc oText ang)
        (if oText (vla-delete oText))
        (princ)
      (while
        (and
          (setq pt2
                 (acet-ss-drag-move
                   ss
                   (trans
                     (setq pt1
                            (vlax-get
                              v
                              (cond
                                 'insertionpoint
                   T
          (or acDoc
        (vlax-invoke (setq oText (vla-copy v)) 'move pt1 pt2)
        (setq ss nil ss (ssadd (vlax-vla-object->ename oText)))
          (progn
            (vla-rotate oText (vlax-3d-point pt2) ang)
          (vla-delete oText)
        (setq oText nil)
      (*error* nil)
    Cheers
    Computer Specs:
    Dell Precision 3620, Core i7-7700K 4.2GHz, 64GB RAM, Samsung 970 Pro M.2, 8GB NVIDIA Quadro P4000
  1. Cannot see Objects as I move or rotate them
    By chrisr in forum AutoCAD General
    Last Post: 2010-07-19, 12:49 PM
  2. Copy/Move/Rotate
    By joshua.harter in forum ACA General
    Last Post: 2010-01-28, 08:58 PM
  3. Rotate then move in a dynamic block
    By Jonathan Pitt in forum AutoCAD General
    Last Post: 2009-06-30, 11:28 AM
  4. rotate then move
    By chad.beussink in forum AutoLISP
    Last Post: 2008-08-22, 01:23 PM
  5. Can not see Objects as I Move them or Rotate them
    By hugvi76 in forum AutoCAD General
    Last Post: 2005-01-19, 10:04 PM
