There is a new system variable in AutoCAD 2016 called DIMLAYER, which when set to a layer name, it puts new dimensions on that layer automatically.
When the command line DIM is used, the dimension goes on the layer specified. However, when the dimension is made with the traditional AutoCAD drop-down menu, or custom tool bars, it does not work, it goes on the current layer. Anyone else have this problem?
