Thread: DIMLAYER system variable not consistently working
    100 Club Brian C's Avatar
    2008-08
    Vancouver, BC
    105
    Default DIMLAYER system variable not consistently working
    There is a new system variable in AutoCAD 2016 called DIMLAYER, which when set to a layer name, it puts new dimensions on that layer automatically.
    When the command line DIM is used, the dimension goes on the layer specified. However, when the dimension is made with the traditional AutoCAD drop-down menu, or custom tool bars, it does not work, it goes on the current layer. Anyone else have this problem?
    Brian C
    "The difference is my flaws are personal. Yours are professional." [Col. Tigh, BSG 2004]
    5,517
    Default Re: DIMLAYER system variable not consistently working
    Quote Originally Posted by Brian C View Post
    By design, DIMLAYER is only observed using the DIM Command... This one of the many reasons I voted against this as a new feature, it's incomplete, and poorly implemented, IMHO.
    You'll need to roll your own Command Reactor, or .NET Event handler to filter for DIM* Commands, and either store CLAYER, set CLAYER == DIMLAYER, restore CLAYER when done, or retroactively apply DIMLAYER value to resultant Dimension-typed entities after-the-fact.
    Cheers
    9,673
    That is as designed as far as I know. The old pull down menus are deprecated and were not updated to call the DIM command, and the now "classic" commands apparently do not honor the DIMLAYER sysvar.
    5,517
    FWIW -
    This is an 'annoauto' app I developed back in 2012, using .NET API to implement a Close() Method Override of an ObjectOverrule (thanks to Tony's help!):
    http://www.screencast.com/users/Blac...4-91cbf42be6c7
    2008-08
    Vancouver, BC
    105
    Thanks Blackbox and Rkm for the clarification. I have been using Autolisp for years to set CLAYER to the dimension layer, then set back to the previous layer after finishing dimensioning. I will look at the .NET app.
    Brian C
    5,517
    Then you're better prepared than most prior to DIMLAYER being introduced, and already equipped to handle the gaps for same; just keep using what you already have, if not enhance your existing code to now also account for DIM Command (+ DIMLAYER, in lieu of DIM* Commands + CLAYER, if that makes sense?).
    No worries - basically, it's an MLEADER sample, that demonstrates the changing of MLeader's Style when layer is changed, and when the layer is changed as the Style is in kind, in order to easily adhere to standards. Same principle for Text, and Dimension entities.
    Cheers
  1. CIVIL 3D SYSTEM VARIABLE
    By mwilson in forum AutoCAD Civil 3D - General
    Last Post: 2011-04-13, 06:47 PM
  2. Image Files created on a 32 bit system not working on a 64 bit system?
    By scott.epp in forum AutoCAD Civil 3D - General
    Last Post: 2010-10-05, 09:59 PM
  3. IMAGEFRAME System Variable
    By joeswantek in forum AutoCAD General
    Last Post: 2007-06-21, 05:11 PM
  4. Snap Overrides not working consistently
    By J. Grouchy in forum Revit Architecture - General
    Last Post: 2005-06-06, 03:15 PM
  5. System variable PSQUALITY
    By Phil Ferguson in forum AutoCAD General
    Last Post: 2005-01-29, 04:57 PM
