Results 1 to 1 of 1
Thread: DL322-1: Autodesk® Revit® MEP: Connect the Dots, Installing the Heart
    Autodesk, Inc. Autodesk University's Avatar
    2012-11
    3,030
    Default DL322-1: Autodesk® Revit® MEP: Connect the Dots, Installing the Heart
    Session: DL322-1
    Title: Autodesk® Revit® MEP: Connect the Dots, Installing the Heart
    Instructor: Ed Hannabas
    Course Description: This class is part of a series that covers the Revit workflow involved in working on large projects. The primary focus of this class is the Autodesk Revit MEP workflow and how that workflow interfaces with the Architectural and Structural disciplines. This course will outline the process of project templates, project setup, and best practices in utilizing Autodesk Revit MEP in the design process. The class is primarily designed to assist project managers, BIM managers and for those personnel who are involved in the set up of projects in Autodesk Revit MEP. Attendees should have a good understanding of Autodesk Revit MEP. This class is focused around the Utah County Convention Center.
  1. AB427-1: Connect the Dots: From Vision to Model
    By Autodesk University in forum Architecture and Building Design
    Last Post: 2015-08-07, 03:47 PM
  2. DL316-1: Connect the Dots: Designing the Body
    By Autodesk University in forum Design Leadership
    Last Post: 2015-08-03, 09:47 PM
  3. DL319-1: Connect the Dots: Creating the Skeleton
  4. DL327-1: Connect the Dots: Making It Flow
  5. DL330-1: Connect the Dots: Minding the Whole
