Results 1 to 1 of 1
Thread: DL330-1: Connect the Dots: Minding the Whole
    Autodesk, Inc. Autodesk University's Avatar
    2012-11
    3,030
    Default DL330-1: Connect the Dots: Minding the Whole
    Session: DL330-1
    Title: Connect the Dots: Minding the Whole
    Instructor: Charlie Busa
    Course Description: This class is part of a series that covers BIM workflows when working on large projects. The primary focus of this class is the assembly of the overall model in Autodesk® Navisworks® Manage and how the model can be used to help the entire team gain a better understanding of the project. Workflow processes for exporting the Autodesk Revit® models, aggregating the models in Autodesk Navisworks and reviewing the results of interference detection will be covered. This class will also review the entire series of sessions and help to tie them all together. Best practices around team planning, workflow planning and team expectations are key to a successful BIM project and will be a topic for the second portion of the session. This session is one of a series of five that uses the Utah County Convention Center as the core of the sessions.
  1. AB427-1: Connect the Dots: From Vision to Model
    By Autodesk University in forum Architecture and Building Design
    Last Post: 2015-08-07, 03:47 PM
  2. DL316-1: Connect the Dots: Designing the Body
    By Autodesk University in forum Design Leadership
    Last Post: 2015-08-03, 09:47 PM
  3. DL319-1: Connect the Dots: Creating the Skeleton
  4. DL327-1: Connect the Dots: Making It Flow
  5. DL416-1: Connect the Dots: Model Aggregation and Collision Detection
