bsaeagle189
In autocad 2016 I am trying to snap to the insertion point on a piece of text. When I try to select the letters of the text I get invalid point. Through investigation I have found that if I hover around the outside of the text I can get the snap to work. I believe that this location corresponds with the text boundary frame. If under options I turn on Text boundary frame only and draw a line in its location and then bring back the text, when my crosshairs cross the line I get the insertion point for the text. This happens with both regular text and mtext.
1. Can I change a setting to allow me to be able to select the letters themselves?
2. If not can I change the boundary frame distance to be closer to the text?
Thank you.
