Session: AB334-1V
Title: Existing Buildings to BIM Buildings with Autodesk® ImageModeler™
Instructor: Amy Fietkau
Course Description: Did you know that images of a building can be used to create a 3D model? Well, it's true. Autodesk ImageModeler is a subscription-based application from Autodesk that allows you to do just that! In this class, we'll look at how images can be calibrated using points and measurements. Then we'll take the time to mass up a building from those points and import it into other applications for further use. If you do renovation work or need to model existing buildings for facilities management, this class is just what you're looking for.
