Session: DV422-1
Title: Revit® to 3ds Max® via Autodesk® FBX®
Instructor: Charles Prettyman
Course Description: You've designed a fabulous building, and now you need to show it off. AutoCAD® Revit can render pretty well, it gets you probably 95% of what you need. To get that last 5%, you're going to want to move your model over to a more specialized rendering application, like Autodesk® 3ds Max®. This one hour lecture will look at the Autodesk FBX file format as an exchange mechanism. Topics will include Export settings from Revit, View templates, Import and Linking options in Max, and common workflow considerations.
