Session: DV416-1
Title: Foundational Workflow for Rendering in Autodesk® 3ds Max® Design
Instructor: Dan Chasteen
Course Description: Would you like to make a smooth transition to rendering in Autodesk 3ds Max Design? Or become more proficient at creating quality renderings? Following a good workflow can bring order to the rendering process and significantly improve your Autodesk 3ds Max Design skills. The class will cover 12 solid steps for producing rendered images from design geometry linked or imported from Revit®, AutoCAD®, and Google SketchUp™. See how to remove variables and substitute constants to progressively step through the rendering process with confidence. Hear the tricks for maintaining short progress renderings, and the rules for when to lock and clear cached data. Discover why settings differ for exterior and interior renderings and how to illuminate interiors without setting up dozens of lights. Follow along as Dan demonstrates this clear workflow for producing rendered images with Autodesk 3ds Max Design and mental ray®.
