Results 1 to 1 of 1
Thread: MA333-6: Step on the Design Accelerator in Autodesk® Inventor®
    Autodesk, Inc. Autodesk University's Avatar
    2012-11
    3,030
    Default MA333-6: Step on the Design Accelerator in Autodesk® Inventor®
    Session: MA333-6
    Title: Step on the Design Accelerator in Autodesk® Inventor®
    Instructor: Bill Fane
    Course Description: The Autodesk Inventor Content Center contains a collection of stock components, such as bearings and bolts, to speed up the design process. The Design Accelerator makes the process even faster. You do not need your handbook to find the correct formula, calculate the required sizes, and then model the parts and assemble them. Just enter the performance specifications and the Design Accelerator does the rest. For example, you can design a V-belt drive by entering the input power and speed, the ratio, and the center-to-center distance. The Design Accelerator calculates the sheave and belt sizes, selects the stock sizes that come closest to meeting your specifications, and adjusts the center distance accordingly before inserting the models directly into your assembly. If you change anything, then everything updates.
  1. MA333-9P: Everyday Uses of Autodesk® Inventor® iLogic™
    By Autodesk University in forum Manufacturing
    Last Post: 2015-08-07, 05:34 PM
  2. MA333-4U: The Doctor Is "In" at the Autodesk® Inventor® ER
    Last Post: 2015-08-07, 05:33 PM
  3. CP218-1: Taking the Step from VBA Macros to Autodesk Inventor Add-Ins
    Last Post: 2014-12-01, 01:58 AM
  4. MA35-2: Step on the Accelerator in Autodesk Inventor®!
    Last Post: 2013-04-17, 04:55 AM
