Session: MA422-5
Title: Creating Efficient Facility Layouts with the Autodesk® Factory Design Suite
Instructor: James Herzing
Course Description: Are you facing the challenges in creating and managing your facility layouts? Are you unable to clearly communicate layout ideas and design proposals? Are you spending too much time manually creating and updating drawings for equipment installation? Do you often run into clashes and clearance issues during equipment installation? Do your layout projects often run over budget and behind schedule? Autodesk® Factory Design Suite is an easy to use 2D and 3D factory layout solution, purpose-built to help you make better layout decisions. Targeted specifically towards machine and equipment builders, system integrators, and manufacturers, it helps you to better design, optimize, and visualize your factory floor layouts.
