Results 1 to 1 of 1
Thread: MA220-1L: I Love This Sheet Metal! Using Autodesk® Inventor® 2011 to Create Precision Sheet Metal Parts
    Autodesk, Inc. Autodesk University's Avatar
    2012-11
    3,030
    Default MA220-1L: I Love This Sheet Metal! Using Autodesk® Inventor® 2011 to Create Precision Sheet Metal Parts
    Session: MA220-1L
    Title: I Love This Sheet Metal! Using Autodesk® Inventor® 2011 to Create Precision Sheet Metal Parts
    Instructor: Rollin Godette
    Course Description: This lab explores the sheet metal environment in Autodesk Inventor 2010. The class leads you on a journey through Autodesk Inventor's extensive set of sheet metal tools as you build a sheet metal guard for a machine that features cutouts, mitered corners, arc-welded corner reliefs, sheet metal fasteners, punched features, and three-bend corners. You will control creating and unfolding your model by using the new integrated Bend Table Editor to create your own bend table. You will set default feature creation by setting up your own sheet metal styles in the Style and Standard Editor. You will review the flat pattern and document your designs in the Drawing Manager. You will also learn to use flat pattern extents to determine the size of the stock required and recover punch centers, and you will use punch tables and punch notes to document features made with the Punch tool. Finally, you will create bend tables, bend notes and bend tags to document how the flat sheet will be fabricated.
  1. MA316-6: Get Your Sheet Metal Together! Autodesk® Inventor® 2011
    By Autodesk University in forum Manufacturing
    Last Post: 2015-08-07, 05:33 PM
  2. Replies: 0
    Last Post: 2014-12-01, 03:49 AM
  3. 2015: Inventor 2015 - Sheet Metal -Create Flat Pattern from sweep along path
    By arminm1988414598 in forum Inventor - General
    Last Post: 2014-07-28, 09:11 AM
  4. MA315-3: Sheet Metal: Autodesk® Inventor™ on the Cutting Edge
    Last Post: 2013-05-06, 01:26 AM
  5. Copy & utilize sheet metal rules on Derived & Mirrored sheet metal parts
    Last Post: 2012-10-18, 12:40 PM
