Results 1 to 7 of 7
Thread: Filtering for Dynamic Blocks using XData - Need help with XData.ASArray
    2012-01
    Texas
    40
    Default Filtering for Dynamic Blocks using XData - Need help with XData.ASArray
    I am trying to filter for a dynamic block using xdata. I found this post by Kean Walmsley going over the process, but I haven't been able to make it work for me. The code he has is in C#, which I'm not familiar with (I code very rarely).
    This is what I have so far:
            Dim doc As Document = Application.DocumentManager.MdiActiveDocument
            Dim db As Database = doc.Database
            Dim ed As Editor = doc.Editor
            Using tr As Transaction = doc.TransactionManager.StartTransaction()
                Dim bt As BlockTable = tr.GetObject(db.BlockTableId, OpenMode.ForWrite)
                For Each bid In bt
                    Dim btr2 As BlockTableRecord = tr.GetObject(bid, OpenMode.ForWrite)
                    If Not btr2.Name = "PointMarker" AndAlso IsDBNull(btr2.XData) = False Then
                        Dim TypeValArr() As TypedValue = btr2.XData.AsArray
                        For i = 0 To TypeValArr.Length
                            Dim TypeVal As String = TypeValArr(i)
                            If TypeVal.GetTypeCode = DxfCode.ExtendedDataRegAppName Then
                                If TypeVal.ToString = "AcDbBlockRepBTag" Then
                                    For j = i + 1 To TypeValArr.Length
                                        TypeVal = TypeValArr(j)
                                            i = j - 1
                                            Exit For
                                        End If
                                        If TypeVal.GetTypeCode = DxfCode.ExtendedDataHandle Then
                                            If TypeVal.ToString = "PointMarker" Then
                                                Dim blockref As BlockReference = btr2.Id.GetObject(OpenMode.ForWrite)
                                                Dim xpos As Double = blockref.Position.X
                                                Dim ypos As Double = blockref.Position.Y
                                                Dim zpos As Double = blockref.Position.Z
                                                Dim scalefactor As Double = blockref.ScaleFactors.X
                                                blockref.ScaleFactors() = New Scale3d(sf)
                                                Dim ac As AttributeCollection = blockref.AttributeCollection
                                                For Each att As ObjectId In ac
                                                    Dim attr As DBObject = att.GetObject(OpenMode.ForWrite)
                                                    If TypeOf attr Is AttributeReference Then
                                                        Dim ar As AttributeReference = att.GetObject(OpenMode.ForWrite)
                                                        ar.TransformBy(Matrix3d.Scaling(1 / scalefactor, New Point3d(xpos, ypos, zpos)))
                                                        ar.TransformBy(Matrix3d.Scaling(sf, New Point3d(xpos, ypos, zpos)))
                                                    End If
                                                Next
                                                i = TypeValArr.Length - 1
                                                Exit For
                                            End If
                                        End If
                                        j = j + 1
                                    Next
                                End If
                            End If
                            i = i + 1
                        Next
                    End If
                Next
    tr.Commit()
    End Using
    I am stuck on the "Dim TypeValArr As Array = btr2.XData.AsArray" part. It continually causes a fatal error when the code runs. Should I be declaring this differently?
    2009-11
    5,538
    Default Re: Filtering for Dynamic Blocks using XData - Need help with XData.ASArray
    Firstly, you may find this site useful for converting between C# and VB.NET.
    That said, you'll have a much easier time learning from others' examples, source code, etc. if you start learning C# - there's just way more available than for VB - and I say that speaking from experience, as I too started learning VB.NET (stepping up from LISP), ultimately making the decision to switch to C#, and haven't looked back since.
    In Kean's article, btr2.XData is declared as var, which is just a generic container for the TypedValue[] returned by the XData Property.
    So this in C#:
    var tvs = xdata.AsArray();
    ... Is this in VB:
    Dim tvs = xdata.AsArray()
    ... Whereas declaring the actual Type in C#:
    TypedValue[] tvs = xdata.AsArray();
    ... Is this in VB:
    Dim tvs As TypedValue() = xdata.AsArray()
    Computer Specs:
    Dell Precision 3630, Core i9-9900K 5.0GHz, 128GB RAM, Samsung 970 Pro M.2, 8GB NVIDIA Quadro P4000
    2009-11
    5,538
    Here is Kean's source code (C#), converted to VB using the site linked above *untested*
    Imports Autodesk.AutoCAD.ApplicationServices
    Imports Autodesk.AutoCAD.Runtime
    Imports Autodesk.AutoCAD.DatabaseServices
    Imports Autodesk.AutoCAD.EditorInput
    Imports System.Collections.Generic
    Namespace EntitySelection
    	Public Class Commands
    		<CommandMethod("SDB")> _
    		Public Shared Sub SelectDynamicBlocks()
    			Dim doc = Application.DocumentManager.MdiActiveDocument
    			Dim ed = doc.Editor
    			Dim pso = New PromptStringOptions(vbLf & "Name of dynamic block to search for")
    			pso.AllowSpaces = True
    			Dim pr = ed.GetString(pso)
    			If pr.Status <> PromptStatus.OK Then
    				Return
    			End If
    			Dim blkName As String = pr.StringResult
    			Dim blkNames As New List(Of String)()
    			blkNames.Add(blkName)
    			Dim tr = doc.TransactionManager.StartTransaction()
    			Using tr
    				Dim bt = DirectCast(tr.GetObject(doc.Database.BlockTableId, OpenMode.ForRead), BlockTable)
    				' Start by getting the handle of our block, if it exists
    				If Not bt.Has(blkName) Then
    					ed.WriteMessage(vbLf & "Cannot find block called ""{0}"".", blkName)
    					Return
    				End If
    				Dim btr = DirectCast(tr.GetObject(bt(blkName), OpenMode.ForRead), BlockTableRecord)
    				Dim blkHand = btr.Handle
    				For Each bid As var In bt
    					' We'll check each block in turn, to see if it has
    					' XData pointing to our original block definition
    					Dim btr2 = DirectCast(tr.GetObject(bid, OpenMode.ForRead), BlockTableRecord)
    					' Only check blocks that don't share the name :-)
    					If btr2.Name <> blkName Then
    						' And only check blocks with XData
    						Dim xdata = btr2.XData
    						If xdata IsNot Nothing Then
    							' Get the XData as an array of TypeValues and loop
    							' through it
    							For i As Integer = 0 To tvs.Length - 1
    								' The first value should be the RegAppName
    								Dim tv = tvs(i)
    								If tv.TypeCode = CInt(DxfCode.ExtendedDataRegAppName) Then
    									' If it's the one we care about...
    									If DirectCast(tv.Value, String) = "AcDbBlockRepBTag" Then
    										' ... then loop through until we find a
    										' handle matching our blocks or otherwise
    										' another RegAppName
    										For j As Integer = i + 1 To tvs.Length - 1
    											tv = tvs(j)
    												' If we have another RegAppName, then
    												' we'll break out of this for loop and
    												' let the outer loop have a chance to
    												' process this section
    												i = j - 1
    												Exit For
    											End If
    											If tv.TypeCode = CInt(DxfCode.ExtendedDataHandle) Then
    												' If we have a matching handle...
    												If DirectCast(tv.Value, String) = blkHand.ToString() Then
    													' ... then we can add the block's name
    													' to the list and break from both loops
    													' (which we do by setting the outer index
    													' to the end)
    													blkNames.Add(btr2.Name)
    													i = tvs.Length - 1
    													Exit For
    												End If
    											End If
    										Next
    									End If
    								End If
    							Next
    						End If
    					End If
    				Next
    				tr.Commit()
    			End Using
    			' Build a conditional filter list so that only
    			' entities with the specified properties are
    			' selected
    			Dim sf As New SelectionFilter(CreateFilterListForBlocks(blkNames))
    			Dim psr As PromptSelectionResult = ed.SelectAll(sf)
    			ed.WriteMessage(vbLf & "Found {0} entit{1}.", psr.Value.Count, (If(psr.Value.Count = 1, "y", "ies")))
    		End Sub
    		Private Shared Function CreateFilterListForBlocks(blkNames As List(Of String)) As TypedValue()
    			' If we don't have any block names, return null
    			If blkNames.Count = 0 Then
    				Return Nothing
    			End If
    			' If we only have one, return an array of a single value
    			If blkNames.Count = 1 Then
    				Return New TypedValue() {New TypedValue(CInt(DxfCode.BlockName), blkNames(0))}
    			End If
    			' We have more than one block names to search for...
    			' Create a list big enough for our block names plus
    			' the containing "or" operators
    			Dim tvl As New List(Of TypedValue)(blkNames.Count + 2)
    			' Add the initial operator
    			tvl.Add(New TypedValue(CInt(DxfCode.[Operator]), "<or"))
    			' Add an entry for each block name, prefixing the
    			' anonymous block names with a reverse apostrophe
    			For Each blkName As var In blkNames
    				tvl.Add(New TypedValue(CInt(DxfCode.BlockName), (If(blkName.StartsWith("*"), "`" & blkName, blkName))))
    			Next
    			' Add the final operator
    			tvl.Add(New TypedValue(CInt(DxfCode.[Operator]), "or>"))
    			' Return an array from the list
    			Return tvl.ToArray()
    		End Function
    	End Class
    End Namespace
    Computer Specs:
    2012-01
    Texas
    40
    I copied and pasted that, and it worked great. Now I'll have to go through and figure out what I was doing wrong. Thanks a bunch!
    2009-11
    5,538
    Quote Originally Posted by apitcher799568 View Post
    Happy to help; Cheers
    Computer Specs:
    2012-01
    Texas
    40
    I think the difference is that I was not using DirectCast. Can you tell me what its purpose is and when I should be using it?
    2009-11
    5,538
    When you TryCast or cast 'as' a given DBObject as something, you can subsequently check for Null (Nothing) before continuing your code... This is useful when iterating an entire Database, or Selection Set of multiple Types (i.e., Circle, Polyline, etc.) to conditionally test for the appropriate DBObject.
    I only DirectCast when I've previously implemented sufficient code logic such that I already know the DBObject is of a given Type - for example, if I make a Selection Set of all Circles, then I can trust that a DirectCast to Circle will be successful.
    Computer Specs:
  1. Filtering by Xdata
    By JasonSelf in forum AutoLISP
    Last Post: 2014-11-25, 10:30 AM
  2. Replies: 0
    Last Post: 2008-02-09, 01:06 PM
  3. xdata
    By san_k4 in forum VBA/COM Interop
    Last Post: 2005-09-19, 10:29 PM
  4. xdata
    By fletch97 in forum AutoLISP
    Last Post: 2005-08-31, 05:52 PM
  5. Possible xdata?
    By whdjr in forum AutoLISP
    Last Post: 2004-08-25, 03:32 PM
