Thread: Weight and Centroid of Solids and Blocks (with solids in them)
    Past Vice President / AUGI Volunteer peter's Avatar
    2000-09
    Honolulu HI
    1,094
    Default Weight and Centroid of Solids and Blocks (with solids in them)
    It always amazes me what gets left out of AutoCAD.
    Like we have materials, but we don't have densities.
    490 pcf for steel for example.
    Sometimes it is good to know how much something weighs... right?
    Attached you will find a lisp routine called "centroid" and a sample drawing called centroidtest.
    If any of you are interested, could you CRASH test it for me?
    You can add densities to material objects in the materials table.
    If you select items (blocks or solids) it will find the total weight and the centroid.
    P=
    PS.. Found a minor bug, and re-uploaded the zip file.
    AutomateCAD
    2015-12
    2,095
    Default Re: Weight and Centroid of Solids and Blocks (with solids in them)
    No time to test that, but one gotcha: make sure it works on objects waaaaay out in WCS space.
    2000-09
    Honolulu HI
    1,094
    AutoCAD is not accurate far from the origin (No double precision)
    P=
    AutomateCAD
  1. 2014: Microstation Solids to Autocad Solids
    By boyerd492098 in forum AutoCAD General
    Last Post: 2014-05-28, 05:14 PM
  2. Stretching 3D Solids
    Last Post: 2006-04-12, 03:51 PM
  3. 3d solids
    By STEVE.TAYLOR in forum AutoCAD Wish List
    Last Post: 2004-09-21, 07:53 PM
  4. 3d solids
    By STEVE.TAYLOR in forum Revit Architecture - Wish List
    Last Post: 2004-09-13, 02:00 PM
  5. yes/no for solids
    By Martin P in forum Revit Architecture - Families
    Last Post: 2004-06-23, 04:03 PM
