Originally Posted by bmason Problem solved: Here is a link for the solution to fix a registry key: http://knowledge.autodesk.com/suppor...incorrect.html I've got the same prob with C3D2016. I tried this solution, but I have no AdskOsnapTab key under [HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R20.1\ACAD-F000:409\Profiles\<<C3D_Imperial>>\Dialogs\DrawingSettingsDialog. Adding it doesn't help either.
Originally Posted by bmason Problem solved: Here is a link for the solution to fix a registry key: http://knowledge.autodesk.com/suppor...incorrect.html That link is dead. I guess the article moved. I found this one: https://knowledge.autodesk.com/suppo...-Civil-3D.html
View Tag Cloud
Forum Rules
