I'm posting this under C3D because that's the higher functionality of what I'm using and it may be influencing bad behavior.
I'm having and issue with the osnap dialog box. When the dialog is open I used to be able to press E on the keyboard and the snap setting would change on the screen in the box.
The dialog box doesn't accept any keyboard input. Also there are 2 features that are missing: the Select All and Clear All.
In addition to that on the old pc it actually showed some reference to AutoCAD Architectural in the dialog box itself as if it had been reprogrammed. I do not use Architectural and support
has not been able to understand where this is coming from.
FYI this happened on my old pc and this is a new pc - 1 week old, the program was reloaded from DVD and worked upon installation.
I've gone through tech support and no solution at this time.
I've also done AutoCAD repair and reset user profile.
TIA
Brian
