Thread: Revit Maximo Integration Plugin
    2015-09
    5
    Default Revit Maximo Integration Plugin
    The information on the BIM and FM splash page about the Revit/Maximo plugin is incorrect. The tool was actually an IBM led development. The tool isn't dead, it's currently available as part of any enterprise Maximo deployment (7.5+ I believe, but check with IBM) for 'free' (no cost from IBM for the tool, setup will probably cost you real money though). Don't bother contacting Autodesk about it for information, the few folks at ADSK that know the tool even exists will just refer you to IBM.
    An alternative tool is ModelStream by Microdesk. Rather than using a COBIe data export from Revit that only goes one way, ModelStream is bidirectional and allows for custom mapping of parameters. ModelStream, however, is not free although the unofficial pricing I have seen is very reasonable for its capabilities.
    2001-12
    St. Louis
    5,298
    Default Re: Revit Maximo Integration Plugin
    Quote Originally Posted by BrendanD View Post
    Brendan, good to know that tool is alive. I'll try to get that page updated soon.
    Thanks, I hadn't heard of that one yet.
    Melanie Stone
    @MistresDorkness
    ARCHIBUS, FMS/FMInteract and AutoCAD Expert (I use Revit, too)
    Technical Editor
  1. Revit Plug-In for Maximo or Archibus?
    By Wanderer in forum Facilities Management In Practice
    Last Post: 2012-12-28, 03:21 PM
  2. Revit & Viz plugin help
    By tbarnesarc in forum VIZ - General
    Last Post: 2005-07-09, 11:47 PM
  3. Revit to MAX Plugin???
    By Richard McCarthy in forum Revit - Rendering
    Last Post: 2005-02-23, 06:40 PM
  4. Revit to MAX plugin
    By Richard McCarthy in forum Revit Architecture - Wish List
    Last Post: 2005-01-04, 02:43 PM
  5. Revit/VIZ Plugin
    By cliburn in forum Revit Architecture - General
    Last Post: 2004-11-22, 04:52 PM
