Thread: Reload xrefs, but only loaded.
    2011-10
    83
    Default Reload xrefs, but only loaded.
    Hi all,
    I am using small simple routine to reload all xrefs, like below:
    (defun c:XE ()(command "-xref" "reload" "*")
    How to upgrade this routine to reload ONLY loaded xrefs (without unloaded)?
    Thanks.
    2011-10
    83
    Default Re: Reload xrefs, but only loaded.
    I found it on CADTutor forum, if someone interested:
    http://www.cadtutor.net/forum/showth...ded-quot-xrefs
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    8,958
    Quote Originally Posted by Arterius View Post
    Here is another version that will allow you to select a specific XREF to reload, or just reload all loaded XREFs if none are currently selected.
    2011-10
    83
    Thanks Opie, but I got error like this:
    "Command: RX ; error: no function definition: ASC"
    and I don't know how to fix it, even dont know what it means
    The only think which (I think) will make life easier is to reload ONLY xrefs with status: Needs reloading.
    Sometimes I have more then 10 xrefs and previus lisp goes through all and relaod.
    If someone has idea how to modify it I will be grateful.
    Thanks.
    2002-01
    jUSt Here (a lot)
    8,958
    Thanks.
    The code linked to earlier now includes the missing subroutine. The ASC subroutine gets the data from an ASSOCiated element of an entity.
    (defun ASC (ELEMENT ENTITY /) (cdr (assoc ELEMENT ENTITY)))
  1. Reload All Xrefs
    By tsherman698234944 in forum AutoCAD Customization
    Last Post: 2013-12-18, 08:48 PM
  2. 2013: Linked file cannot be loaded because it is loaded into another open document
    By cr_gixxer in forum Revit Architecture - General
    Last Post: 2013-12-04, 08:21 PM
  3. Replies: 0
    Last Post: 2009-01-31, 04:01 PM
  4. Automatically reload changed xrefs
    Last Post: 2006-03-26, 09:11 PM
  5. Automatically reload XREFS
    Last Post: 2006-02-08, 11:32 PM
