Thread: corridor extents as outer boundary - shrinkwrap boundary
    2015-05
    6
    Default corridor extents as outer boundary - shrinkwrap boundary
    Hello,
    I was wondering if anyone has came across an issue where when you use the corridor extents as outer boudary in the corridor that it will cut off you surface in a curb return region. Surface displays fine until adding the boundary. I add the boundary so i can paste the corridor surface into my fg surface and build out the rest of my site using the fg surface. Any tips or ideas what I am doing wrong would be greatly appreciated.
    Thank you
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,145
    Default Re: corridor extents as outer boundary - shrinkwrap boundary
    Is there a gap between your curb return and the remaining corridor? I have found a gap between regions can cause this behavior.
    2014-08
    452
    you might also check the length of your tin lines since they are always straight I have had a curved line cut off one edge that removes the whole face there. there is a setting to adjust the triangulation intervals you may need to set it smaller
  1. how to extract corridor boundary ?
    By robert.248186 in forum AutoCAD Civil 3D - Corridors
    Last Post: 2013-08-29, 02:38 PM
  2. Replies: 0
    Last Post: 2012-03-29, 05:35 AM
  3. Corridor and Boundary
    By mannu21 in forum AutoCAD Civil 3D - Corridors
    Last Post: 2009-11-27, 02:21 AM
  4. Corridor Boundary
    By allyn1980 in forum AutoCAD Civil 3D - General
    Last Post: 2008-04-30, 01:12 AM
  5. Corridor boundary
    By kwdsku in forum AutoCAD Civil 3D - General
    Last Post: 2005-08-09, 02:59 PM
