Thread: Copy page setup from another file
    Default Copy page setup from another file
    Does anyone have any idea why this doesn't work? The important/significant lines are in a small for . . . each loop towards the end.
       Private Sub subCopyPageSetupFromFile()
            Dim strDrvPathFileExt As String
            Dim objSrcDB As New Database
            Dim objTransactionManager As Autodesk.AutoCAD.DatabaseServices.TransactionManager
            Dim objTransaction As Transaction
            Dim objSrcPlotSettingsDictionary As DBDictionary
            Dim objDictionaryEntry As DictionaryEntry
            Dim objPlotSettings As PlotSettings
            strDrvPathFileExt = "C:\ProgramData\Autodesk\ApplicationPlugins\Acad.dwt"
            objSrcDB.ReadDwgFile(strDrvPathFileExt, FileOpenMode.OpenForReadAndReadShare, True, "")
            objTransactionManager = objSrcDB.TransactionManager
            objTransaction = objTransactionManager.StartTransaction
            objSrcPlotSettingsDictionary = objTransaction.GetObject(objSrcDB.PlotSettingsDictionaryId, OpenMode.ForRead)
            For Each objDictionaryEntry In objSrcPlotSettingsDictionary
                objPlotSettings = objTransaction.GetObject(objDictionaryEntry.Value, OpenMode.ForRead)
                MsgBox(objDictionaryEntry.Key.ToString.ToUpper)
            Next
            objTransaction.Dispose()
            objTransactionManager.Dispose()
    End Sub
    5,538
    Default Re: Copy page setup from another file
    Norman's C# code here should help (convert to VB as desired):
    https://forums.autodesk.com/t5/net/i...2698926#M19537
    There's also a good description of how a Layout is a PlotSettings Object; don't be misled by the VB code in that thread.
    Cheers
    5,758
    Also, your code doesn't check for the existence of page setups in the destination dwg. If they already exist, copying them from a source db will not overwrite them. I delete them from the destination db before I start to import them.
    5,758
    Here is my solution. ImportPageSetups.zip contains two commands. PageSetups.zip contains a form and Active.zip contains a class of objects by Scott McFarlane. Add them to your project and rename the namespaces to match your project.
    5,538
    This old thread may be of use as well:
    https://forums.augi.com/showthread.p...=1#post1219546
  1. 2016: Page Setup Manager/Page Setups not importing
    By tbevis730888 in forum AutoCAD General
    Last Post: 2016-07-02, 03:49 PM
  2. Replies: 4
    Last Post: 2013-11-17, 09:49 PM
  3. Copy Page Setup
    Last Post: 2010-03-29, 01:24 PM
  4. Page setup copy?
    By pearlx100 in forum AutoCAD Plotting
    Last Post: 2009-06-08, 10:56 PM
  5. Missing Page Setups in Page Setup Override
    By footprint_arch in forum AutoCAD Sheet Set Manager
    Last Post: 2005-06-15, 08:41 PM
