Results 1 to 9 of 9
Thread: Xref Palette Tree View default?
    2011-09
    308
    Question Xref Palette Tree View default?
    Hi gang,
    Is there a way to get the Xref palette to default to tree view?
    System Variable? LISP? Dark magic?
    -JP
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,051
    Default Re: Xref Palette Tree View default?
    Quote Originally Posted by jpcadconsulting347236 View Post
    Hi gang,
    -JP
    Probably Dark Magic. While in the palette, you can toggle between the two with F3 (List View) & F4 (Tree View).
    2011-09
    308
    Thanks Opie,
    I realized that I did not have "Automatically save changes to workspace" enabled , and so the setting was reverting to "List View" every time I restarted. Driving me nuts.
    I've set that properly and in fact I added the following line to acad.lsp so the workspaces changes are saved for every one here.
    (setvar "wsautosave" 1)
    But now out of sheer curiosity, I wonder if there is a way to force the Tree View on either AutoCAD Launch or File Open.
    2002-01
    jUSt Here (a lot)
    9,051
    I do not have that setting enabled for my workspace.
    I cannot think of a way to toggle the setting.
    2011-09
    308
    Interesting, AutoCAD still does not remember that setting (Tree View).
    2002-01
    jUSt Here (a lot)
    9,051
    It may just not like you today.
    2011-09
    308
    I don't think it likes me on any given day...
    2021-06
    Oh look, the same issue has come up again in C3D 2023.
    Turlock, CA
    6,300
    Are you sure that you're saving changes to your workspace? When you upgrade to a new release, the default is to not save changes. See post 3 or run the WSSETTINGS command. However, there's no need to set it each time in acad.lsp as it is remembered until you change it.
    C:> ED WORKING....
  1. Default Revit RPC Tree - Plan Colour Adjustment
    By craighowie in forum Revit Architecture - Families
    Last Post: 2010-08-26, 01:13 PM
  2. ClassicXref Tree View by default
    By 3dway in forum AutoCAD General
    Last Post: 2009-12-01, 08:53 PM
  3. Tool palette "View Options" default!?
    By jgardner.79905 in forum AutoCAD Customization
    Last Post: 2006-05-15, 04:53 PM
  4. Tool Palette - Object by default Inserts as Block, change to Xref instead?
    By costas.vassiliou in forum AutoCAD Customization
    Last Post: 2006-03-07, 09:53 AM
  5. Default Tool Palette View Options
    By lmendoza in forum AutoCAD General
    Last Post: 2005-03-08, 01:36 PM
Tags for this Thread
