Hello all,
I have a door family with a card reader located at various positions that are set to Yes/No parameters that I can turn on or off depending on where I need the card reader to be located in the project.
So, I have 1 "main" Card Reader parameter (reporting?) that, when checked, auto-populates the door schedule to indicate that that particular door requires a card reader.
and 4 Yes/No parameters to graphically turn on the card reader in the project depending on where I need it located.
Is there a formula that I can write for that main card reader parameter that automatically checks itself when any, or multiple, of the 4 "sub" parameters are turned on, or automatically uncheck if none of the 4 are turned on?
For example:
Main Parameter = A
4 visibility parameters = 1, 2, 3, 4
A is checked if 1 is visible
A is checked if 1 and 2 are visible
A is checked if 1, 2, 3, and 4 are visible.
A is unchecked if none are visible
I can only find a formula that connects two parameters, not one that is connected to multiple..
Thank you
