A user is trying to make PDFs of a plan drawing that has lines at different elevations. However, he is finding that higher-up gray lines (contour lines at actual elevations) are covering up black lines at lower elevations, making them hard to read. This is happening even though we've tried a couple different PDF printers (PDF995 and DWG To PDF.pc3), and have set the lines to "merge" instead of "overlap" for both printers. Is there a way to make gray + black = black, even though the gray is higher up? Nothing I've found in my searches seems to work.
