Thread: Insertion Point
    I could stop if I wanted to kwong's Avatar
    2002-11
    270
    Default Insertion Point
    Hi all,
    I made a boxed text to insert as a symbol; how do make it so I can have the insertion point where I want it, for example 10mm below & right of the box? Thanks.
    kwong
    2003-05
    5,153
    Default Re: Insertion Point
    In the generic annotation template, the reference planes define the insertion point.
    Make the box with dimension parameters 10mm above and left of the insertion point.
    Save and load into a project and use as a symbol.
    Bruce Gow.
    Karel*CAD. Application Specialist..
    Architect.
    Revitalize. Blog
  1. Replies: 21
    Last Post: 2012-10-10, 02:38 PM
  2. MLEADER INSERTION POINT (?)
    By clxramos583784 in forum VBA/COM Interop
    Last Post: 2012-06-22, 05:44 PM
  3. RL insertion point
    By kristreagus in forum Dynamic Blocks - Technical
    Last Post: 2007-11-08, 03:33 AM
  4. Placing insertion point at mid-point of flange on a steel section
    By Spenner in forum Dynamic Blocks - Technical
    Last Post: 2007-06-18, 01:53 PM
  5. Insertion Point
    By kwong in forum Revit Architecture - General
    Last Post: 2005-03-19, 07:27 AM
