Thread: POINT STYLE
    2004-06
    Slidell, Louisiana
    921
    Default POINT STYLE
    Just curious. I see that cogo points have a style for the marker and a point label style for the text. if you select one and go to properties you can turn off (true or false) the label and
    the leader, but is there a way to turn off the marker? I don't see where that is possible.
    My work around was to create a new style that has a blank marker and just change styles.
    2014-08
    407
    Default Re: POINT STYLE
    Hi
    turn off the light bulb in the display tab or make a new none style with no marker
    2004-06
    Slidell, Louisiana
    921
    I don't have a light bulb on the display tab on the properties palette.
    Cairo - no, not Illinois
    4,968
    Not in properties. You need to edit the Point Style on the Settings tab of Toolspace.
    Be aware that will impact every point that is using that style.
  1. 2015: Point Style
    By tim_newsome in forum AutoCAD Civil 3D - General
    Last Post: 2014-11-10, 09:42 PM
  2. 2013: Point Label Style - Dragged State - Point to Node
    By sebastien795355 in forum AutoCAD Civil 3D - General
    Last Post: 2013-11-04, 04:10 PM
  3. Set default Point Style
    By chrisg.75432 in forum AutoCAD LT - General
    Last Post: 2006-04-07, 02:25 PM
