Results 1 to 8 of 8
Thread: need reset or update?
    2015-10
    10
    Default need reset or update?
    My AutoCAD is running terrible
    I don`t know if it is something I did or someway to reset to default or update..
    AutoCAD 2005 version N.84.0
    serial # <snip>
    license ID <snip>
    PC HP p7-1020 8BG RAM, 64 bit operating system, windows 10
    processor AMD Phenom tm II, X4 960T 3 GHZ...
    Cairo - no, not Illinois
    4,750
    Default Re: need reset or update?
    that's an eleven year old version of CAD, running on an eleven week old version of Windows.
    I would expect on-going, un-fixable problems on a regular basis.
    If you can't afford, or don't want to upgrade to AutoCAD 2016 w/ SP1 -- the version that is actually supported on Win10, then perhaps an alternative CAD package would work better for you. Graebert and Bricsys both have excellent DWG compatible applications, and the free-to-use-for-any-purpose Draftsight is a very nice and light weight 2d program.
    Disclaimer -- Acad 2005 was always my favorite version, it hit the perfect sweet spot between usable features, performance, and bloat. But that was then and this is now.
    0,0,0 The Origin
    8,569
    or use an older operating system (Windows XP SP3 [32-bit] or SP2 [64-bit] - inside a virtual machine, if necessary.
    John B
    2015-10
    10
    Well looking better I uninstalled and reinstalled and then used compatible mod twice and reverted to windows 7 settings and seems to work ok..I hope..
    2015-10
    10
    Yes, AutoCAD 2005 working better than ever. Now if I could learn how to change from 3d to a 2d view for shop drawings?
    2015-10
    10
    Pay no attention to last, I concluded I can draw in same model to one side and create a
    side view for shop drawings, then add another layout template for plotting.
    0,0,0 The Origin
    8,569
    Quote Originally Posted by violy.michael711351 View Post
    It sounds as if you are trying to model and draw plans all in model space. Don't.
    Create your model in model space, switch to a layout tab and create viewports with a view from a different direction in each.
    The layout will also hold your plot settings.
    John B
    2015-10
    10
    Sounds fine, I`ll try , thanks
  1. Update/Reset Attributes to default values?
    By Mr Cory in forum AutoLISP
    Last Post: 2017-07-01, 05:07 AM
  2. 2015: Update Release 6 for Subscription update R2?
    By steven.187898 in forum Revit Architecture - General
    Last Post: 2015-02-20, 07:56 AM
  3. Origin reset
    By mlf in forum AutoCAD 3D (2007 and above)
    Last Post: 2009-09-01, 06:45 PM
  4. Out of Date Table: Update All / Skip Update
    By .chad in forum ACA Wish List
    Last Post: 2007-06-08, 01:33 PM
  5. Variable Reset
    By IanR in forum AutoCAD Wish List
    Last Post: 2004-09-18, 05:40 PM
