Thread: Why won't linked file category honor graphic overrides?
    2004-06
    Memphis TN area
    7,047
    Default Why won't linked file category honor graphic overrides?
    I have a roof plan with several Duct objects in a linked file from my HVAC consultant. His duct objects show up with green lines by default. I went them to be black, and a heavier line weight in my roof plan. I went to my roof plan View Template and changed the Duct category to have thicker, black Projection lines. No change. I went to the VT and went into the linked file's overrides, changed to Custom, and changed the Ducts category again to have thicker, black Projection lines. Still not change, they're still showing up with green lines.
    What is the problem here, why won't it take on the settings I'm telling it to do?
    AERC, PLLC
    Hernando, Mississippi
    All AUGI, all the time Duncan Lithgow's Avatar
    2006-09
    Denmark
    612
    Default Re: Why won't linked file category honor graphic overrides?
    I has this problem and discovered that it's because ducts are not colored by category, but by rather by classification. That is an property of the duct. I'm still not quite sure how it works, or why our VG overrides don't work. But I made filters catching the same parameter and voilá - it works.
    2004-06
    Memphis TN area
    7,047
    Quote Originally Posted by Duncan Lithgow View Post
    Well there are some other objects with the same issue. Some PVC pipe plumbing vents for example, and a rooftop exhaust ventilator fan.
    AERC, PLLC
    2002-09
    Madison, WI
    5,674
    It's based on your system color setting.
    Each "System" type in revit has them. You can change and adjust them by changing the V/G settings of the systems.
    I can't remember exactly where you do it at, but I know the help page was actually useful for this one.
    One way to fix this is to apply a filter to all of the systems (which are ducts, pipes and such) and choose the parameter value of system and set it equal to *.
    Then you can adjust the VG of they system without messing around with the link.
    At least that's my guess as to why you can't change the color of them.
    Hope this helps.
    Dave Peterson
    BIM Coordinator
    Acad - 2019 - Revit 2020 w/ BIM 360 - Navisworks - 3ds 2020 - Ensacpe - Lumion - Win 7 64 - i7-8086K 4.0GHz 32GB Ram - Nvidia Quadro P2000
    "The more you know, the less you know, because the more you know you don't know". --M. Lin
    2006-09
    Denmark
    612
  1. Replies: 9
    Last Post: 2017-05-18, 04:54 AM
  2. Separate Phase Graphic Overrides for linked models.
    By Wish List System in forum Revit MEP - Wish List
    Last Post: 2013-05-15, 04:53 PM
  3. Templating Visb/Graphic Overrides to Linked Arch. model
    By Buzter in forum Revit Structure - General
    Last Post: 2012-05-18, 12:55 PM
  4. graphic override of element in linked file
    By cr_gixxer in forum Revit Architecture - General
    Last Post: 2012-05-01, 07:16 PM
  5. Phase Graphic Overrides - by Category
    By ron.sanpedro in forum Revit Architecture - Wish List
    Last Post: 2007-06-22, 12:14 AM
