Thread: dialog boxes won't open from standard toolbar or pulldown menu
    2015-10
    12
    Default dialog boxes won't open from standard toolbar or pulldown menu
    Suddenly, when I use the Standard toolbar buttons or the pulldown menus to open or saveas drawings, the dialog boxes don't open. Instead I am forced onto the command line, and can't browse to find the file I want. The problem seems to only occur with these commands: new/qnew, open, saveas. Other commands work OK.
    Everything was fine until I had a few recent drawing crashes. There were problems with the file which I fixed by dint of various audits and wblocking the whole drawing. Not sure whether that's related or not. I've tried rebooting my computer and restarting Autocad, but that doesn't help. The problem occurs whether or not I already have a drawing open.
    Is there a way to fix this without re-installing Autocad? Thanks for any suggestions.
    - - - Updated - - -
    Never mind - as soon as I posted this a similar thread popped up. Reset FILEDIA to 1 and all is solved. Thanks AUGI!!
    2001-12
    St. Louis
    5,406
    Default Re: dialog boxes won't open from standard toolbar or pulldown menu
    Quote Originally Posted by gill View Post
    - - - Updated - - -
    Thanks for taking the time to post your solution. Glad you found something that worked! :mgreen:
    Melanie Stone
    @MistresDorkness
    Technical Editor
  1. No 'Open" or 'Save-as' Dialog Boxes...???
    By kleenhippie in forum AutoCAD General
    Last Post: 2008-09-05, 05:18 PM
  2. Command dialog boxes no longer open
    By recook in forum AutoCAD General
    Last Post: 2007-01-26, 07:48 PM
  3. Open a PDF file to a specific page from pulldown menu
    By john.lauer in forum AutoCAD Customization
    Last Post: 2006-05-31, 09:03 PM
  4. Extract or Open Dialog Boxes
    By mjfarrell in forum AutoCAD Customization
    Last Post: 2004-10-11, 06:34 PM
  5. express menu dialog boxes
    By bbapties in forum AutoCAD General
    Last Post: 2004-06-17, 09:00 PM
Tags for this Thread
