I am trying to make a rule for all pipes to end at inner wall of structure...so far, so good. I chose "Structure Inner Wall" in the pipe rule set dialog box and all the pipes are set to use the rule. However, the point at which the pipe ends at the structure is still at the elevation at the center of structure (the rule is not being followed?). Do I need to also set offsets for the start and end of pipe in order to "hit" the structure at the correct elevation? That would mean a different rule for each different size structure, right? I have a label style made to label the end of the pipes with their elevation, but they are incorrect by .01 or .02, just enough to have a reviewer go crazy when they compare my labels with the survey inverts! As it is, I am going crazy instead, thanks for any help.
