Thread: Draw Polyline needing x,y,&z coordinates from collection
    2015-11
    3
    Default Draw Polyline needing x,y,&z coordinates from collection
    Background:
    I receive a .dxf with points. These points are arrayed in x,y,& z coordinates. I have extracted the coordinates into collections and I am trying to draw a polyline using those coordinates as vertices. It is important that the z coordinate be included. All points differ in their x,y,z coordinates.
    The collection is a collection of arrays (0 to 2).
    This was my attempt to call vertices straight from the collection:
    ThisDrawing.ActiveLayer = newLayer
    Set pLineA = ThisDrawing.ModelSpace.Add3DPoly(pointCollA.Item(1), pointCollA.Item(2), pointCollA.Item(3), _
                                                    pointCollA.Item(4), pointCollA.Item(5), pointCollA.Item(6), _
                                                    pointCollA.Item(7), pointCollA.Item(8), pointCollA.Item(9), _
                                                    pointCollA.Item(10), pointCollA.Item(11), pointCollA.Item(12), _
                                                    pointCollA.Item(13), pointCollA.Item(14), pointCollA.Item(15), _
                                                    pointCollA.Item(16), pointCollA.Item(17), pointCollA.Item(18), _
                                                    pointCollA.Item(19), pointCollA.Item(20), pointCollA.Item(21), _
                                                    pointCollA.Item(22), pointCollA.Item(23), pointCollA.Item(24), _
                                                    pointCollA.Item(25))
    ThisDrawing.ActiveLayer = newLayer1
    Set pLineB = ThisDrawing.ModelSpace.Add3DPoly(pointCollB.Item(1), pointCollB.Item(2), pointCollB.Item(3), _
                                                    pointCollB.Item(4), pointCollB.Item(5), pointCollB.Item(6), _
                                                    pointCollB.Item(7), pointCollB.Item(8), pointCollB.Item(9), _
                                                    pointCollB.Item(10), pointCollB.Item(11), pointCollB.Item(12), _
                                                    pointCollB.Item(13), pointCollB.Item(14), pointCollB.Item(15), _
                                                    pointCollB.Item(16), pointCollB.Item(17), pointCollB.Item(18), _
                                                    pointCollB.Item(19), pointCollB.Item(20), pointCollB.Item(21), _
                                                    pointCollB.Item(22), pointCollB.Item(23), pointCollB.Item(24), _
                                                    pointCollB.Item(25))
    Result is: Compile error: Wrong number of arguments or invalid property assignment.
    Thank you for help!
    2015-11
    3
    Default Re: Draw Polyline needing x,y,&z coordinates from collection
    BTW ive tried this with AddPolyline & AddLightWeightPolyline too.
    Turlock, CA
    6,372
    You pass it an array object, not a list of points. Here's the sample from the help file.
    Sub Example_Add3DPoly()
        Dim polyObj As Acad3DPolyline
        Dim points(0 To 8) As Double
        ' Create the array of points
        points(0) = 0: points(1) = 0: points(2) = 0
        points(3) = 10: points(4) = 10: points(5) = 10
        points(6) = 30: points(7) = 20: points(8) = 30
        ' Create a 3DPolyline in model space
        Set polyObj = ThisDrawing.ModelSpace.Add3DPoly(points)
        ZoomAll
    End Sub
    C:> ED WORKING....
    2015-11
    3
    Yep. Thank you. What I wasn't realizing was that i needed to initialize it with the first two points and then append it for the rest of the vertices.
    Here was my end result.
    Dim points(0 To 5) As Double
    Dim points1(0 To 2) As Double
    Dim pLineA As Acad3DPolyline
    Dim pLineB As Acad3DPolyline
    index = 0
        For Each coords In railOne
            If index < count Then
                If index < 1 Then
                    handle = railOne(index)
                    Set object = ThisDrawing.HandleToObject(handle)
                        points(0) = object.Coordinates(0)
                        points(1) = object.Coordinates(1)
                        points(2) = object.Coordinates(2)
                    index = index + 1
                        points(3) = object.Coordinates(0)
                        points(4) = object.Coordinates(1)
                        points(5) = object.Coordinates(2)
                        Set pLineA = ThisDrawing.ModelSpace.Add3DPoly(points)
                        index = index + 1
                Else
                        points1(0) = object.Coordinates(0)
                        points1(1) = object.Coordinates(1)
                        points1(2) = object.Coordinates(2)
                    pLineA.AppendVertex points1
                    index = index + 1
                End If
            Else
            End If
        Next coords
    Thank you for the help!!!!
  1. Select polyline and get coordinates
    By avinash patil in forum Dot Net API
    Last Post: 2012-11-04, 08:24 PM
  2. Polyline Coordinates finding
    By avinash patil in forum VBA/COM Interop
    Last Post: 2012-08-30, 11:29 AM
  3. 3D Polyline coordinates
    By lmitsou in forum AutoLISP
    Last Post: 2008-07-17, 08:49 PM
  4. Replies: 8
    Last Post: 2007-06-07, 07:53 PM
  5. Can I draw lines using coordinates eg 44˚34.00'N 125˚26.0'W
    By strenge in forum AutoCAD Map 3D - General
    Last Post: 2007-01-14, 08:22 AM
