Results 1 to 6 of 6
Thread: Combine Door and Window Schedules
    2015-10
    3
    Default Combine Door and Window Schedules
    I am relatively new to Revit, so maybe there is an easy answer to this that I have not found.
    I need to combine exterior doors and windows into a single fenestration schedule with areas and u-values for all exterior openings for energy code compliance. I was thinking that multi category schedule might work, but it looks like you can't do area calculations in that type of schedule. Anyone have a method for this?
    2015-12
    52
    Default Re: Combine Door and Window Schedules
    Do I understand correctly: You are unable to insert a Calculated Value field into Multi-Category schedule?
    2009-11
    380
    Add shared parameters to the door and window families to report width and height, then do a calculated value for the area. Also do the SHGC an U-values as shared parameters to schedule in a multi-category.
    2015-10
    3
    So if I am understanding this...
    When I try to do a multi category schedule the width and height are not listed as available fields, but if I create a new shared parameter for width and height in my window and door families and use that instead I should be able to add those fields to the multi category schedule and use it for calculations - is that right?
    2015-12
    52
    why not create a calculated value to extract the room area using room:volume divided by room:unbounded height. Both fields are available in a multi-category schedule.
    2006-04
    149
    I'm attempting to do the same thing. I need to create a schedule that shows the U-Vaule and SHGC. I only need to show the Mark, Description, U-Vaule & SHGC. The first issue I'm haivng is isolating just the doors & windows in the multi-category schedule. I put in some Filters saying category equals Doors & another for category equals windows, and everything disappeared from the schedule! The second question/issue is how do I get the U-Vaule & SHGC to be shared into the schedule. Right now both vaules are in the each door & window family under Analytical Properties, they are greyed out and their values determined through formulas based on the Analytical construction.
  1. Live elevation door and window schedules - not static legend views
    Last Post: 2018-08-05, 10:43 PM
  2. Combine schedules
    By sblackburn in forum Revit Architecture - General
    Last Post: 2017-03-03, 03:17 AM
  3. door and window schedules
    By jwenzeljr in forum Revit Architecture - General
    Last Post: 2010-07-19, 07:54 PM
  4. Door / Window Schedules & Schedule Tags
    By mflure.80520 in forum ACA General
    Last Post: 2005-04-15, 04:55 PM
  5. Window & Door Schedules - graphics
    By trombe in forum Revit Architecture - General
    Last Post: 2004-01-26, 02:59 PM
