I am new to sheet sets and have followed Sheets Happen! I have set a up a sheet set template DST file. I have set up multiple dwt files and have assigned custom properties to the blocks and using a separate title block that is being X-ref'd. My issue is when creating a new sheet set (from my template DST file) for new/existing clients the custom properties retains fields from the template sheet set. Also when I edit the block attributes to update the fields to reflect the correct sheet set the field still does not update. I have to use the enhanced attribute editor to get the field to update. I did follow sheets happen on this part, by making sure I added the fields using the text editor and filling the default text line. I have attached a snapshot showing both sheet sets being referenced.
I have also tried deleting and purging the block information and then reinserting it. This provides another mystery; I still have to update the fields to reflect the correct sheet set. As I'm doing this I can see the fields update with the proper text from the custom properties. Upon exiting the block editor the attributes still show the default information and not the custom properties text.
One other thing I want to mention. I have tried both ways to start a new sheet set. Using the "An example sheet set" option will copy over the custom properties I saved in the template sheet set. By using the "Existing drawings" option, this will not copy over any custom properties.
Does anyone have any ideas on how to correct this? Please let me know if you need more information.
