Thread: Revolving door for curtain panel?
    2004-07
    Pretoria, South Africa
    29
    Default Revolving door for curtain panel?
    Have anybody done a revolving door for a curtain panel system? Please post the family.
    AUGI Addict luigi's Avatar
    2015-11
    Royal oak, Michigan
    1,513
    Default Re: Revolving door for curtain panel?
    There are revolving doors at www.revitcity.com, but they work for doors, so all you need to do is select the panel of the curtain wall, switch the panel to be a wall(almost any from your list) and then insert the door in the wall. (make sure you delete the mullion from the floor if you have one.
    2004-07
    29
    Cool Re: Revolving door for curtain panel?
    Thanks, actually a strait forward problem i forgot you can change a panel in Revit 7 into a wall
  1. Revolving curtain wall door
    By Rodger in forum Revit Architecture - Families
    Last Post: 2012-05-25, 09:05 PM
  2. Revolving Door for Curtain Walls
    By phyllisr in forum Revit Architecture - Families
    Last Post: 2011-06-27, 05:11 PM
  3. way to change curtain panel to curtain door panel?
    By Justin Marchiel in forum Revit Architecture - General
    Last Post: 2008-01-16, 09:07 PM
  4. Revolving Door in Curtain Wall
    By agreven in forum Revit Architecture - General
    Last Post: 2005-02-10, 04:38 PM
  5. How to change a curtain panel to a door curtain panel?
    By sbrown in forum Revit Architecture - General
    Last Post: 2003-12-17, 06:13 AM
