Results 1 to 10 of 18
Thread: Keep attribute properties when updating blocks
    0,0,0 The Origin
    8,570
    Default Keep attribute properties when updating blocks
    I change the colour of specific attributes within blocks. (Don't ask, its a long answer).
    Is there a way to keep the colours when updating the blocks with new versions? The attribute labels and (text) contents remain the same.
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,106
    Default Re: Keep attribute properties when updating blocks
    Not that I can think off hand. When the attributes are synchronized with the block definition, the color of the attribute would also be updated. You may be able to extract the colors prior to the synchronization and the replace the colors, but this will take programming of some nature.
    2005-06
    in the upper right corner
    3,507
    Silly question..(maybe this doesn't work). why don't you change the color of the raw attributes of the new block?
    Then when you attsync they should take on those properties.
    0,0,0 The Origin
    8,570
    Because there are a dozen attributes in each block and, at any one time, any, all or none of them might have had a different colour applied; the base colour in the block definitions is White so that they are not affected by layer. At the moment, I place a coloured rectangle around non-White attributes before updating the blocks - it allows me to change the colours but its a PITA with a thousand blocks in a hundred drawings.
    Opie, yes, thanks, that what I thought.
    2002-01
    jUSt Here (a lot)
    9,106
    Try these two autolisp routines. This is dependent on the handle remaining the same between updates. The first routine saves a list of handles of each attribute with the currently assigned color of the attribute. The second restores the color of that handle. If an error occurs, it will stop / crash. No error handling is implemented at the moment.
    Step 1: Save Attribute Colors
    (defun c:SaveAttColors (/ cnt y l)
      (defun :VLA_GET_COLOR	(object / COLOR-METHOD COLOR-OBJECT color-list)
        (setq color-object (vla-get-TrueColor object)
    	  color-method (vla-get-ColorMethod color-object)
        (cond ((= color-method acColorMethodByRGB)
    	   (setq color-list
    		  (mapcar
    		    '(lambda (l) (vlax-get color-object l))
    		    '(Red Green Blue)
    	  ((= color-method acColorMethodByACI)
    	   (setq color-list (vla-get-ColorIndex color-object))
        (setq color-list
    	   (cons (vla-get-handle object)
    		 (list color-method color-list)
      (setq lstHandles nil)
      (repeat (setq cnt (sslength (setq y (ssget '((0 . "INSERT"))))))
        (foreach n
    	     (m:safelist
    	       (vla-getattributes
    		 (vlax-ename->vla-object (ssname y (setq cnt (1- cnt))))
          (setq l (append l (list (vla-get-handle n))))
      (if l
        (setq lstHandles
    	   (mapcar
    	     (function (lambda (x)
    			 (:vla_get_color
    			   (vlax-ename->vla-object (handent x))
    	     l
    Step 2: Attribute Synchronize (if needed)
    Step 3: Restore Attribute Colors
    (defun c:RestoreAttColors (/)
      (defun :VLA_SET_COLOR	(object color-list / COLOR-METHOD)
        	(setq color-object
    	       (vla-GetInterfaceObject
    		 (setq :ACAD_OBJECT (vlax-get-acad-object))
    		 (strcat "AutoCAD.AcCmColor."
    			 (substr (getvar 'ACADVER) 1 2)
        (setq color-method (nth 0 color-list))
        (vla-put-ColorMethod color-object color-method)
        (if	(= color-method acColorMethodByRGB)
          (vla-SetRGB
    	color-object
    	(nth 0 (setq color-list (nth 1 color-list)))
    	(nth 1 color-list)
    	(nth 2 color-list)
          (vla-put-ColorIndex color-object (nth 1 color-list))
        (vla-put-TrueColor object color-object)
        (vlax-release-object color-object)
        object
      (if (and lstHandles
    	   (= (type lstHandles) 'LIST)
        (foreach n lstHandles
          (:VLA_SET_COLOR
    	(vlax-ename->vla-object (handent (car n)))
    	(cdr n)
      (princ)
    0,0,0 The Origin
    8,570
    Thanks for that, Opie.
    Unfortunately the result is -
    ; error: no function definition: M:SAFELIST
    followed by an unhandled exception with the message that Application does not support JIT debugging. Why, I have no idea.
    2002-01
    jUSt Here (a lot)
    9,106
    Sorry about that.
    Add these two subroutines and it should work.
    ;_ Convert Safearray to list
    (defun m:safelist (value)
      (if (= (type value) 'VARIANT)
        (setq value (m:variantvalue value))
      (setq value (vl-catch-all-apply 'vlax-safearray->list (list value)))
      (if (vl-catch-all-error-p value)
        nil
        value
    ;_ Get value of variant
    (defun m:variantvalue (value)
      (setq value (vl-catch-all-apply 'vlax-variant-value (list value)))
        nil
        value
    0,0,0 The Origin
    8,570
    Sorry about that.
        nil
        value
        nil
        value
    Close. The Save seems to work but Restore gives -
    ; error: null interface pointer: #<VLA-OBJECT 0000000000000000>
    2002-01
    jUSt Here (a lot)
    9,106
    Are you doing this in the same drawing session? Can you provide a sample drawing or two showing the various steps?
    0,0,0 The Origin
    8,570
    Yes, all within one session.
    Here is a file with two instances of the block and a copy of the revised block and my copy of your code.
  1. 2015: Field in an Attribute not updating
    By derek.96018 in forum AutoCAD Customization
    Last Post: 2015-09-09, 05:06 PM
  2. Updating blocks nested within Dynamic Blocks
    By mattr.143859 in forum Dynamic Blocks - Technical
    Last Post: 2009-09-30, 04:14 PM
  3. Updating blocks nested within Dynamic Blocks
    By mattr.143859 in forum CAD Management - General
    Last Post: 2009-09-28, 01:09 PM
  4. Replies: 11
    Last Post: 2007-05-17, 06:56 AM
  5. updating attribute text
    By thomas_raftery in forum AutoCAD General
    Last Post: 2005-04-25, 03:24 PM
