Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Keep attribute properties when updating blocks
  1. #11
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,105
    2
    Default Re: Keep attribute properties when updating blocks
    Quote Originally Posted by jaberwok View Post
    Yes, all within one session.
    Here is a file with two instances of the block and a copy of the revised block and my copy of your code.
    See the revised code for the RestoreAttColors above.
  2. #12
    0,0,0 The Origin
    8,570
    Superb! Exactly what I needed. Thanks again.
  3. #13
    2012-05
    Planet Earth
    10
    @Opie
    Would that be possible to tweak your code in order to preserve attributes width factor as well as (or instead of) its color?
  4. #14
    2002-01
    jUSt Here (a lot)
    9,105
    Yes. The calls to the sub-routines included in each save / restore routine would need to be modified to save and restore the ScaleFactor of each attribute.
  5. #15
    0,0,0 The Origin
    8,570
    A follow-up - this also works when using ATTSYNC.
    good stuff.
  6. #16
    2002-01
    jUSt Here (a lot)
    9,105
    Glad to hear this works for that situation, too.
  7. #17
    0,0,0 The Origin
    8,570
    I'm sooo glad this is still here. I suffered a disastrous HD crash.
    This time I've also saved it to an external drive.
    [and immediately after that post my ISP connection disappeared for the night. ]
  8. #18
    0,0,0 The Origin
    8,570
    @Opie.
    Four years later and I still use these routines every week.
    Great stuff.
  1. 2015: Field in an Attribute not updating
    By derek.96018 in forum AutoCAD Customization
    Last Post: 2015-09-09, 05:06 PM
  2. Updating blocks nested within Dynamic Blocks
    By mattr.143859 in forum Dynamic Blocks - Technical
    Last Post: 2009-09-30, 04:14 PM
  3. Updating blocks nested within Dynamic Blocks
    By mattr.143859 in forum CAD Management - General
    Last Post: 2009-09-28, 01:09 PM
  4. Replies: 11
    Last Post: 2007-05-17, 06:56 AM
  5. updating attribute text
    By thomas_raftery in forum AutoCAD General
    Last Post: 2005-04-25, 03:24 PM
