Hello, I have acad lt 2005 when I use the double line command "DL" the snaps are turned off. If I type "s" at the command line for Snap option it has an ON/OFF toggle its set to on and still no snaps. I can turn snaps on by using the F3 key, but all of my default snaps are cleared and I have to pick each individually. When I exit the command the default snaps are restored. I have to manually turn snaps on each time I use the double line command.
Whats up with this? Is this the way its supposed to be?
Thanks Jim
