Results 1 to 7 of 7
Thread: Insert Points from a Table
    2006-04
    21
    Default Insert Points from a Table
    Is it possible to create a table which when created will place points based on the XY coordinates in the table? There is a List routine which will place points from an Excel spreadsheet but since an Autocad table behaves very much like an Excel spreadsheet I was wondering this could be done.
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,106
    Default Re: Insert Points from a Table
    It's possible to convert the AutoLISP routine to work with the AutoCAD table object instead. Can you post the routine?
    2006-04
    21
    I found a copy at jefferypsanders.com.
    http://www.jefferypsanders.com/autolisp_IMPORTXYZ.html
    Can't seem to load the lisp itself but this is the link to it.
    Thank you
    2002-01
    jUSt Here (a lot)
    9,106
    Do you have a sample drawing?
    2012-02
    82
    I can't insert test file I want to send. I see that there is an Insert Video button and an Insert Image button to drop stuff into the thread but there ain't no Insert file button. Drag and drop doesn't work.
    Manage Attachments doesn't do anything but **** me off.
    2002-01
    jUSt Here (a lot)
    9,106
    Does this thread help? If not, please start a new thread and give us more information on your steps.
    2012-02
    82
    Let's try this again,,, with feeling!
  1. Insert dynamic block into table
    Last Post: 2013-11-13, 12:43 PM
  2. Insert table as block keeping it editable
    By alissonvilela888400 in forum AutoCAD Tables
    Last Post: 2012-04-02, 01:02 PM
  3. Insert Blocks with Survey Points
    By civil3d.wishlist1941 in forum Civil 3D Wish List
    Last Post: 2009-01-31, 03:07 PM
  4. points table display
    By rjairath in forum AutoCAD Civil 3D - General
    Last Post: 2008-02-21, 10:02 PM
  5. insert block by selecting a points
    By windowsxp5 in forum AutoLISP
    Last Post: 2006-04-24, 12:09 PM
