Thread: Text Color
    2012-02
    82
    Default Text Color
    I have brought the contents of an Excel spreadsheet into a DWG. The text comes in as black. Even though I have specified that the contents are ByLAYER. I can't get the text to change to yellow unless I explode the table and explode the Mtext then select everything and change it to the style and color I want.
    How do I bring the contents of a spreadsheet into a file and the text is the color I want? I have to change the Row height, Text Style, Justification, blah, blah, blah. It's a pain in the butt.
    Earth
    9,803
    Default Re: Text Color
    How did you import it? Copy in Excel and then Paste as AutoCAD entities?
    R.K. McSwain | CAD Panacea |
    2012-02
    82
    Yes. That is what I did.
    Earth
    9,803
    When you say it comes in "black", I presume you mean it comes in color 7 (white on a black/dark background -or- black on a white/light background)
    True. If you go into the cell, and select the text, the Text Formatting toolbar will show that the color is hardcoded to color 7, for each bit of text in each cell.
    This post covers stripping the property overrides from multiple table cells.
    http://through-the-interface.typepad...using-net.html
    This page contains a LISP file that will do what you want:
    https://cadabyss.wordpress.com/2010/...ripmtext-v5-0/
    2012-02
    82
    I will have a look at your links. I did find one way around it and that is to change the color of the text in Excel. That does it. The text style still doesn't look quite right though (I did select a specific Text Style once the table was in place).
  1. Text Color
    By LTM586 in forum Revit - Platform
    Last Post: 2014-04-14, 08:17 PM
  2. Replies: 3
    Last Post: 2012-12-19, 03:00 PM
  3. Text Color
    By Sevans-MEP in forum Revit MEP - General
    Last Post: 2010-02-01, 07:32 PM
  4. Linetypes with text color.
    By kmf2797 in forum AutoCAD General
    Last Post: 2009-07-24, 06:39 PM
  5. dim text export color
    By sjsl in forum Revit Architecture - General
    Last Post: 2006-01-12, 03:58 PM
