I am trimming out existing contours from within a closed boundary. Sounds simple, right?
Except, each time I click on a contour to trim it the outcome is completely random, one of three things happen:
a.) It trims the line correctly.
b.) It completely misses the trim line and cuts out the entire contour.
c.) It fails to Trim whatsoever and I have to resort to the "BREAK" command.
This seems to be even more of an issue now than it was in previous releases. This happens in 2013, 2014 and 2015.
Another issue is that if I fence a bunch of contours, say 20 and try to trim all at once, the computer hangs and sometimes it crashes CAD.
My contours are all 2D polylines and my trim line is a LWPOLYLINE at elevation = 0m
It seems that the TRIM command does not work as it should and Autodesk really need to fix this as it has only gotten worse over time.
See the attached image for what I mean.
