Results 1 to 7 of 7
Thread: Dialog Box Color Change In Windows 10
    2001-11
    236
    Default Dialog Box Color Change In Windows 10
    AutoCAD 2016 on Windows 10.
    Where in Windows 10 do I change the colors of my dialog box.
    My Contrast Themes are way off from what I need and could not find what theme
    I currently have. In the color themes, I can change almost all colors except the
    left blueish pane on the left. What's the trick here?
    Thanks.
    Earth
    9,805
    Default Re: Dialog Box Color Change In Windows 10
    IDK about the blue background, but you can change the text from white to black. See this post.
    R.K. McSwain | CAD Panacea |
    2001-11
    236
    But that post seem to refere to Windows 7. I have Windows 10 and can't find Window Color And Appearance.
    Am still looking. Or maybe in Win10, it's called something else.
    Thanks though for your help.
    Earth
    9,805
    Quote Originally Posted by omorah View Post
    Google is your friend.
    See: http://www.intowindows.com/how-to-op...in-windows-10/
    2001-11
    236
    Yep, Google sure is my "friend"!
    I saw the link when I googled for solutions. According to the attached image,
    the AutoCAD color is supposed to march that of Windows 10 setting, black text
    on white background, but it's not happening. Guess am missing something here.
    2001-11
    236
    (Update)
    By the way, what I need to change is the left pane on the dialog boxes.
    According to the previous image, the AutoCAD's has the blueish color with
    white text while the PhotoDraw has gray background color with white text.
    The method to do this in Windows 10 does not show how to change the left
    pane in the dialog box.
    Thanks.
    2001-11
    236
    Well, I found something that did it. It's called Classic Color Panel utility. It's a small file that don't need to be installed; in case someone else is interested.
    Windows 10 color customization:
    https://www.makeuseof.com/tag/custom...-10-free-tool/
    Classic Color Panel utility:
    https://www.wintools.info/index.php/download
  1. Color Dialog in VBA
    By KevinBarnett in forum VBA/COM Interop
    Last Post: 2018-10-19, 03:49 PM
  2. Replies: 4
    Last Post: 2015-11-03, 02:24 PM
  3. Replies: 8
    Last Post: 2015-01-06, 01:15 PM
  4. 2015: Need To Change A Color In The Color Index.
    By omorah in forum AutoCAD General
    Last Post: 2014-08-04, 11:43 AM
  5. LISP for change yellow color into Color 8
    By rhodinj1427782 in forum AutoLISP
    Last Post: 2014-01-16, 05:26 AM
