Thread: How to find length of line shape intersecting various polygon shapes
    2004-10
    49
    Default How to find length of line shape intersecting various polygon shapes
    I have a drawing that is set to the desired datum. I have connected to two shape files, "snowmobile trails" and "vegetation cover type" (see attached jpg). I want to find the number of miles of snowmobile trail that pass through each of the hundreds of different vegetation cover types. "Cover type" is a column header in the vegetation cover type database. So the end result I am looking for is a data table that provides a new column heading specifying the length for each "snowmobile trail x cover type". I have successfully intersected the two shape files into a sdf, using Analyze tab/Feature panel/Feature Overlay. What I need is a new column heading that tells me the length of each new trail segment (trail segment x cover type). I don't know how to proceed from here. Any help?
    Kelly
    2004-10
    49
    Default Re: How to find length of line shape intersecting various polygon shapes
    Perhaps I am asking my question incorrectly. I just want to know the sum of the length of snowmobile trail through each of the various vegetation cover types. Snowmobile trails are in one shape file, Cover Types in another. And I also created an intersect of the two. Perhaps I can find the answer with a query? I typically don't do analysis with CAD, just mapping. If I need GIS data analysis I find someone who knows what they are doing. But I don't have that luxury this week. Any help would be appreciated.
    Kelly
    TN/KY Area
    1,640
    Once you do the overlay analysis you can do a calculation on the SDF file/layer. Open the table and click on the options at the bottom and select Create Calculation.
    J. Murphy
    AKA
    Murph
    The former AutoCAD MAP3D Power User
    2004-10
    49
    Murph, thanks a ton! So simple, yet I wasted a bunch of time trying to figure it out on my own! I appreciate your help!
    TN/KY Area
    1,640
    Quote Originally Posted by kscolfer View Post
    Your welcome anytime.
    J. Murphy
    AKA
    Murph
  1. Exporting to Polygon shape files
    By bamagnuson in forum AutoCAD Map 3D - Import/Export
    Last Post: 2011-04-05, 10:34 PM
  2. Replies: 1
    Last Post: 2008-11-06, 01:39 PM
  3. Find Polygon Diagonals
    By MikeJarosz in forum VBA/COM Interop
    Last Post: 2007-07-11, 01:41 AM
  4. Ability to Find Intersecting Loop Errors
    Last Post: 2007-06-21, 09:08 PM
  5. Polygon topology exports extra records to shape file
    By jim.dahl in forum AutoCAD Map 3D - General
    Last Post: 2006-05-09, 09:17 PM
