I've searched for hours now and can't determine what's wrong. I've been working in Revit for about a year now, and I'm still finding things that amaze me, and things the frustrate me. This is one of the latter.
The issue: in my floor plan, my walls are showing only the finish lines. I've tried dozens of suggestions from forums & autodesk help, but to no avail. My cut plan is set at 4'-0". If I build a pony wall up to 3'-0", the walls shows a white fill. All walls that cross that 4'-0" plane show a solid grey fill. I don't even need to turn the finish layers off, I just need to be able to see the core layers so I can dimension to them.
I have a completed building/model that I'm creating construction documents on. Our office standard is to have framing plans dimensioned from stud to to stud (so from the left side of stud #1 to the left side of stud #2, ignoring wall thickness). Everyone draws in AutoCAD except for me, and I'm spearheading the transition to Revit.
The tricks I thought had the most chance of working (but didn't) are:
1. Changing my dimension toolbar to "Faces of Core" allows me to dimension to the studs, but you can't see the studs to see what I'm dimensioning.
2. I've tried every variant of Visibility/Graphic Overrides I can find or think of
3. I've tried every variant of "Override Host Layers" (Cut Line Styles) I can find or think of.
4. Changing the Detail Level from Course to Fine doesn't affect it.
I'm at a loss, but I can't complete a framing plan without making this work, and I really don't want to have to export everything to AutoCAD to create my sheets.
Here's a picture of one area where I've dimensioned to the wall cores using "Faces of Core" in the dimensioning toolbar. This is our standard, but I have to be able to see the core.
Thoughts? Thanks for any help.
I'm using the Revit Design Suite 2016.
