I have a section of code that creates a new layout and sets if current. It works in 2014 AutoCAD but I cannot get it to work in 2016 AutoCAD. I combed through this several times and cannot figure out why it keeps erring out. It catches the error at the line "LayoutManager.Current.CurrentLayout = acLayout2.LayoutName"
Any help would be greatly appreciated.
Public Sub CreateLayout(ByVal db As Database, ByVal ed As Editor, ByVal doc As Document, ByVal LayName As String, ByVal myPSxrefs As ArrayList)
Using tr As Transaction = db.TransactionManager.StartTransaction()
Try
Using layouts As DBDictionary = DirectCast(tr.GetObject(db.LayoutDictionaryId, OpenMode.ForWrite), DBDictionary)
' Add a number at the end of layout name if already exists
Dim i As Integer = 0
Dim OriginalName As String = LayName
Dim x As Double = 25.4 * CDbl(TB_X.Text)
Dim y As Double = 25.4 * CDbl(TB_Y.Text)
Dim myPlotOrigin As Point2d = New Point2d(y, x)
' Create and activate the new layout
Using myLockDoc As DocumentLock = doc.LockDocument()
Dim acLayoutMgr As LayoutManager = LayoutManager.Current
Dim layoutId As ObjectId = acLayoutMgr.CreateLayout(LayName)
Dim acLayout2 As Layout = tr.GetObject(layoutId,
OpenMode.ForRead)
If acLayout2.TabSelected = False Then
End If
'Plot Settings
'' Get the PlotInfo from the layout
Using acLayout As Layout = DirectCast(tr.GetObject(layoutId, OpenMode.ForWrite), Layout)
Dim acPlInfo As PlotInfo = New PlotInfo()
acPlInfo.Layout = acLayout.ObjectId
'' Get a copy of the PlotSettings from the layout
Dim acPlSet As PlotSettings = New PlotSettings(acLayout.ModelType)
acPlSet.CopyFrom(acLayout)
'' Update some properties of the PlotSettings object
Dim acPlSetVdr As PlotSettingsValidator = PlotSettingsValidator.Current
Dim myCTB As String = "LBI-Full.ctb"
Dim device As String = "Bluebeam PDF"
acPlSetVdr.SetCurrentStyleSheet(acPlSet, myCTB)
acPlSetVdr.SetPlotConfigurationName(acPlSet, device, myMediaCanonical)
If CB_SheetRotation.Text = "LANDSCAPE" Then
acPlSetVdr.SetPlotRotation(acPlSet, PlotRotation.Degrees090)
End If
If CB_SheetRotation.Text = "PORTRAIT" Then
acPlSetVdr.SetPlotRotation(acPlSet, PlotRotation.Degrees000)
End If
If CB_SheetRotation.Text = "LANDSCAPE(Upside Down)" Then
acPlSetVdr.SetPlotRotation(acPlSet, PlotRotation.Degrees180)
End If
If CB_SheetRotation.Text = "PORTRAIT(Upside Down)" Then
acPlSetVdr.SetPlotRotation(acPlSet, PlotRotation.Degrees270)
End If
acPlSetVdr.SetPlotType(acPlSet, DatabaseServices.PlotType.Layout)
acPlSetVdr.SetZoomToPaperOnUpdate(acPlSet, True)
acPlSetVdr.SetPlotOrigin(acPlSet, myPlotOrigin)
acPlSetVdr.SetUseStandardScale(acPlSet, True)
If myPSxrefs.Count > 0 Then
attachXrefsTypes(myPSxrefs, "TTBL")
End If
ed.Regen()
'' Update the layout
acLayout.CopyFrom(acPlSet)
End Using
End Using
tr.Commit()
End Using
Catch ex As System.Exception
Dim Msg As String = "Error in function Create Layout"
Dim Title As String = "Operation cancelled"
MessageBox.Show(Msg, Title, MessageBoxButtons.OK, MessageBoxIcon.Exclamation, MessageBoxDefaultButton.Button1)
MsgBox(ex.Message & Err.Number)
tr.Abort()
End Try
End Using
End Sub
